SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
SOURCE: projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
SOURCE: I have a DLP Benq projector (not sure the model
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
SOURCE: I forget the password for the projector BenQ Mp620 Datashow
tolong klo ada yang tau cara gimana mengembalikan fassword yang terkunci di layar projector BENQ MP620
SOURCE: cannot reset lamp counter on
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
