Question about Frigidaire Ovens
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
SOURCE: frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
Posted on Feb 01, 2009
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Posted on Mar 21, 2009
SOURCE: my frigidaire gas range has a F90 on it when I
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
SOURCE: how do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Apr 25, 2012
Good Morning James, thanks for your post!
From my understanding your broiler feature is not working on your Frigidaire wall oven and the element is good. It could be a potential issue with the thermostat or connector of wall oven. If there is a miscommunication within the wall oven you may be able to perform a reset to clear the issues. If you would like to attempt a reset you would need to flip the household circuit breaker off for roughly ten minutes. If that does not correct your issue I would recommend contacting a professional technician for assistance in diagnosing your wall oven. Hope this is helpful. -Matt
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
