SOURCE: carrier jam
your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
SOURCE: Carrier jam Lexmark 4300
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
SOURCE: Reset Lexmark 36 Black cartridge?
BINGO just refill my 36 and printing :) just place tape (2) on the bottom the outside points
ONLY THE ONE OUTSIDE BOTH SIDES :) :) :)
HP his something like this too. 2nd try BINGO IT WORK drill right hole place tape back over refill hole LOL
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
Sometimes the ink
cartridge carrier won't automatically move to its loading position even when
the printer is on and the cover is open. Follow the steps below:
1. Unplug the
printer from the power source.
2. With the cover
open, hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the cartridge carrier to the center of
the printer.
3. Remove the
used cartridges.
4. Load the new
cartridges. Close the cover.
5. Plug the printer back to the power source.
The Lexmark manual says: Remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. See pic below...
