Question about Hayward Pool & Spa
SOURCE: usig/overriding freeze protection on a pol/spa filtering system
Any entry into SERVICE mode from the outside panel will override a freeze protect. Be sure to put it back to AUTO in order to resume freeze.
Posted on Dec 21, 2008
SOURCE: Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Posted on Jan 06, 2009
SOURCE: have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Posted on Jun 22, 2009
SOURCE: Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Posted on Sep 17, 2009
SOURCE: Hayward Pool Freeze Protection Switch
Yes their is a temp sensor or thermal bulb depending on the unit.
Posted on Oct 04, 2009
Sep 24, 2014 | Hayward H Series Pool & Spa Heater 400k...
Dec 06, 2013 | Hayward Pool & Spa
Sep 24, 2013 | Hayward Pool & Spa
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Sep 25, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
135 people viewed this question
