Cell Phones Logo
R
Ron Grant Posted on Jan 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the language on me Nextbook 9 from Spanish to English
Marvin
Level 3:
Top Expert:
  • Cell Phones Master 85,242 Answers
  • Posted on Jan 07, 2017
Marvin
Cell Phones Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024156
Points
266281
If you click (on the main screen) in the top right corner on the (6) little squares. Then slide through the pages on the first tab. Do this until you see a picture icon of a grey square, outlines in blue with blue lines and dots on it. The first line will be slightly farther to the right than the second and the bottom (third) bar will be almost completely across the box. Select that. Then on the left hand side look slightly farther down the mid ways. you will see a choice that has a picture icon that looks like a sticky note with "A" on it and beside it will say "Idioma y entrada". Select that. at the top on the right select "Idioma" Then scrol and select "English(United States)". Unless you are in the UK, Select "English" UK
1helpful
How to change language in samsung sph400
The display language is preset to English. To change the language, from the standby screen, press Menu > Settings > Phone Settings > Language. Choose from English, Espa?ol (Spanish), or Chinese for both the screen text and input language. Note: If you accidentally change your language to Espa?ol and need to reset it to English, from the standby screen, press Menu 9 5 2, select English, and press the OK key.
My laptop is in spanish how do I change to english
You need to make two changes:-
Go to Control Panel
1. Pick the Language Icon and change the language to English
2. Pick the Keyboard Icon and change it to Spanish Keyboard.
Change language spanish english
Greeting sir I have VTech tab for kids it's in spanish..kindly tell me how change it Spanish to English.
Waiting for your answer.
Change language from Spanish to English Vizio 323SV
You need to use the remote to go to the setup menu and set the language to English, or if you are in the USA set it to US English, which is different from English.
My computer had some loging in problems and when i took it to get fixed they changed the language from English to Spanish (where i live they speak spanish). I want it to go back to English but i cant...
You do the below seteps: This is what you do:
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages tab. If you see a drop down list of languages, see if it is set to English. If not, set to English. However, if you do not have this list there, you may need to install it.
5helpful
Change langage
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
5helpful
2answers
My verizion env2 phone was switched from english to spanish. how do I change it back. I do not speak spanish
Open the the phone and hit the OK button for the menu
Press 9 which is settings and tools.
Press 6 which is the phone settings.
Pressing 4 will get you the Language selection.
Use the direction pad to
scroll to a ENGLISH, then press OK.
Should be good to go.
Hope this helps,
Bill
3helpful
How can I change the language on my laptop?
If you just want to change the keyboard and general language settings, you simply go to the Start Menu -> Control Panel -> Regional/Language settings and change your language.
If your friend installed the Turkish version of WinXP (i.E. all the alert boxes are in Turkish) and you want to modify it to another language - that's a totally different and more complex situation.
In order to change the whole system language you can install a newer service pack in a different Language or uninstall the last installed Service Pack and after changing the registry settings below Install it again.
!!!Make always a backup of your Registry first !
You have XP SP2 in Turkish and want to change your systmes language to English, you will have to download SP3 in English (link).
(You can change the language here to another one before the download.)
Then you will have to change some registry keys. (Go to HKEY_LOCAL_MACHINESYSTEMControlSet001ControlNlsLanguage Registry Key), and change the value for “Default” and “InstallLanguage” from 041F (Turkish) to 0409 (English).
Reboot and you'll be able to install SP3 in English.
If no problems occur, you will have the whole system language changed.
Here is the List of numbers that represents each language in the registry:
* 0436 = "af;Afrikaans"
* 041C = "sq;Albanian"
* 0001 = "ar;Arabic"
* 0401 = "ar-sa;Arabic (Saudi Arabia)"
* 0801 = "ar-iq;Arabic (Iraq)"
* 0C01 = "ar-eg;Arabic (Egypt)"
* 1001 = "ar-ly;Arabic (Libya)"
* 1401 = "ar-dz;Arabic (Algeria)"
* 1801 = "ar-ma;Arabic (Morocco)"
* 1C01 = "ar-tn;Arabic (Tunisia)"
* 2001 = "ar-om;Arabic (Oman)"
* 2401 = "ar-ye;Arabic (Yemen)"
* 2801 = "ar-sy;Arabic (Syria)"
* 2C01 = "ar-jo;Arabic (Jordan)"
* 3001 = "ar-lb;Arabic (Lebanon)"
* 3401 = "ar-kw;Arabic (Kuwait)"
* 3801 = "ar-ae;Arabic (you.A.E.)"
* 3C01 = "ar-bh;Arabic (Bahrain)"
* 4001 = "ar-qa;Arabic (Qatar)"
* 042D = "eu;Basque"
* 0402 = "bg;Bulgarian"
* 0423 = "be;Belarusian"
* 0403 = "ca;Catalan"
* 0004 = "zh;Chinese"
* 0404 = "zh-tw;Chinese (Taiwan)"
* 0804 = "zh-cn;Chinese (China)"
* 0C04 = "zh-hk;Chinese (Hong Kong SAR)"
* 1004 = "zh-sg;Chinese (Singapore)"
* 041A = "hr;Croatian"
* 0405 = "cs;Czech"
* 0406 = "the;Danish"
* 0413 = "nl;Dutch (Netherlands)"
* 0813 = "nl-be;Dutch (Belgium)"
* 0009 = "en;English"
* 0409 = "en-us;English (United States)"
* 0809 = "en-gb;English (United Kingdom)"
* 0C09 = "en-au;English (Australia)"
* 1009 = "en-ca;English (Canada)"
* 1409 = "en-nz;English (New Zealand)"
* 1809 = "en-ie;English (Ireland)"
* 1C09 = "en-za;English (South Africa)"
* 2009 = "en-jm;English (Jamaica)"
* 2809 = "en-bz;English (Belize)"
* 2C09 = "en-tt;English (Trinidad)"
* 0425 = "et;Estonian"
* 0438 = "fo;Faeroese"
* 0429 = "fa;Farsi"
* 040B = "fi;Finnish"
* 040C = "fr;French (France)"
* 080C = "fr-be;French (Belgium)"
* 0C0C = "fr-ca;French (Canada)"
* 100C = "fr-ch;French (Switzerland)"
* 140C = "fr-lu;French (Luxembourg)"
* 043C = "gd;Gaelic"
* 0407 = "de;German (Germany)"
* 0807 = "de-ch;German (Switzerland)"
* 0C07 = "de-at;German (Austria)"
* 1007 = "de-lu;German (Luxembourg)"
* 1407 = "de-li;German (Liechtenstein)"
* 0408 = "el;Greek"
* 040D = "he;Hebrew"
* 0439 = "hi;Hindi"
* 040E = "hu;Hungarian"
* 040F = "is;Icelandic"
* 0421 = "in;Indonesian"
* 0410 = "it;Italian (Italy)"
* 0810 = "it-ch;Italian (Switzerland)"
* 0411 = "ja;Japanese"
* 0412 = "ko;Korean"
* 0426 = "lv;Latvian"
* 0427 = "lt;Lithuanian"
* 042F = "mk;FYRO Macedonian"
* 043E = "ms;Malay (Malaysia)"
* 043A = "mt;Maltese" 0414 = "no;Norwegian (Bokmal)"
* 0814 = "no;Norwegian (Nynorsk)"
* 0415 = "pl;Polish"
* 0416 = "pt-br;Portuguese (Brazil)"
* 0816 = "pt;Portuguese (Portugal)"
* 0417 = "rm;Rhaeto-Romanic"
* 0418 = "ro;Romanian"
* 0818 = "ro-mo;Romanian (Moldova)"
* 0419 = "ru;Russian"
* 0819 = "ru-mo;Russian (Moldova)"
* 0C1A = "sr;Serbian (Cyrillic)"
* 081A = "sr;Serbian (Latin)"
* 041B = "sk;Slovak"
* 0424 = "sl;Slovenian"
* 042E = "sb;Sorbian"
* 040A = "es;Spanish (Traditional Sort)"
* 080A = "es-mx;Spanish (Mexico)"
* 0C0A = "es;Spanish (International Sort)"
* 100A = "es-gt;Spanish (Guatemala)"
* 140A = "es-cr;Spanish (Costa Rica)"
* 180A = "es-pa;Spanish (Panama)"
* 1C0A = "es-do;Spanish (Dominican Republic)"
* 200A = "es-ve;Spanish (Venezuela)"
* 240A = "es-co;Spanish (Colombia)"
* 280A = "es-pe;Spanish (Peru)"
* 2C0A = "es-ar;Spanish (Argentina)"
* 300A = "es-ec;Spanish (Ecuador)"
* 340A = "es-cl;Spanish (Chile)"
* 380A = "es-uy;Spanish (Uruguay)"
* 3C0A = "es-py;Spanish (Paraguay)"
* 400A = "es-bo;Spanish (Bolivia)"
* 440A = "es-sv;Spanish (El Salvador)"
* 480A = "es-hn;Spanish (Honduras)"
* 4C0A = "es-ni;Spanish (Nicaragua)"
* 500A = "es-pr;Spanish (Puerto Rico)"
* 0430 = "sx;Sutu"
* 041D = "sv;Swedish"
* 081D = "sv-fi;Swedish (Finland)"
* 041E = "th;Thai"
* 0431 = "ts;Tsonga"
* 0432 = "tn;Tswana"
* 041F = "tr;Turkish"
* 0422 = "uk;Ukrainian"
* 0420 = "your;Urdu"
* 042A = "vi;Vietnamese"
* 0434 = "xh;Xhosa"
* 043D = "ji;Yiddish"
* 0435 = "zu;Zulu"
Need to change language for spanish to english
just go to teh site mobile heart.com and download the software for any language
1helpful
2answers
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
