Question about Vtech Toys
How do I factory reset my vtech v reader to where it can be setup again!
Posted by The Pumpkin Man on
Alyssa DeWolfe
    Habit-Forming:
  • 27 Answers
Apparently you can disconnect all power supplies (batteries and adapter), then reconnect all power supplies. Press the ON/OFF button. Remove the storybook cartridge, clean it if necessary, then re-insert it into the V.Reader.
I've also included the product manual as a link.
There doesn't seem to be any real answers online for this, but if you're out of options, I'd contact their customer service team at https://www.vtechkids.ca/en/support/form or call 1-877-352-8697.
Posted on Apr 18, 2020
When ever i call a certain number it wnt call and it says that i need to change the restriction
go through the manual to see the different functions it has.
there is an option to reset the phones to default. It will erase everything, then the phone will need to be setup again.
http://www.manualslib.com/manual/187956/Vtech-6041.html
Dec 09, 2013 | Vtech Cordless 6041 Phone
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
Either software or device issues? The software doesnt recognize the device!
Here's a lil tip 4 u...not all softwares work properly in a computer even if its installed/downloaded properly with the instructor's manual
try returning it back with your insurance guiding it then get a new one and try it again...good luck
Dec 28, 2011 | Vtech V.reader Reading System
V reader won't turn on
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the v.reader, but at least you'll get it working again.
vtech could have made it a very simple problem to solve just by adding in their customer support: Blue Screen? follow these steps. But they don't, so here's how:
You'll need an SD card with at least 64mo of free space. If you want to use the one from your camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website, but it took me a while to get there)
For the US version
http://contentcdn.vtechda.com/vtechkidsDownload/US/VReader/Tool/Recover/US-engRecoverCardTool.exe
For the Canadian english version
http://contentcdn.vtechda.com/vtechkidsDownload/CA-eng/VReader/Tool/Recover/CA-engRecoverCardTool.exe
This is the link to the website itself:
http://www.vtechkids.com/download/ca/en
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that. And since there's no reset button on the v.reader, this is the only way to erase the 100+ drawings that your child saved.
Hope that helps
Nov 18, 2011 | Vtech V.reader Animated E-book System
My Reader Library icon will not open. I had purchased e books then it said there was a problem and I had to close. When I tried to open again it does nothing.
Hi there.
What OS are you running? Try to restoring your computer to the date before you installed the new version of the reader library.
If you have Windows 7, set eBook Library to Vista compatibility to get it to run.
Let me know what happens.
Thank you for using Fixya!
Jun 03, 2011 | Sony Reader Pocket PRS-300
Forgot password
Welcome to Fixya. The security key can be found when you access the wireless settings page of the router. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank.
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
If you have questions please let me know. Thanks for using Fixya.
May 15, 2011 | Belkin (F5D7231-4) Wireless Router
Vtech V Reader says "No
You need a SD Memory card for the v.reader in order to download books to it.
Dec 26, 2010 | Vtech V.reader Animated E-book System
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Toys Logo
969 people viewed this question
Top Vtech Toys Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Anthony Ward
Anthony Ward
Are you a Vtech Toy Expert? Answer questions, earn points and help others
