Washing Machines Logo
James Archer Posted on Jan 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is a code on a maxima Maytag front load washer E01 F06
Level 3:
  • Maytag Master 19,187 Answers
  • Posted on Jan 07, 2017
Maytag Master
Level 3:
Answers
19187
Questions
0
Helped
4339517
Points
82259
That is a communication error between the motor control board and the main control board. Since washing machines vibrate a lot, you need to unplug it and check the wire cable inside the machine that connects those boards, see if the wires are loose, corroded or broken. Unplug them and plug them back in. Then apply power and see if it is working. It may be one of those boards is bad though and that is expensive
Level 3:
Top Expert:
  • Maytag Master 76,851 Answers
Maytag Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986685
Points
237762
053
Try this code. For more http://homenol.blogspot.com/
Visit the site. Pull up older posts.
2answers
My friend has a Maytag maxima washer. It has water under the spinner . It won't spin out and reads codes e02 f06?
Found this...check it out...
https://www.justanswer.com/appliance/8xplq-maytag-maxima-front-load-washer-error-codes-f06.html
Part here....
https://www.repairclinic.com/Shop-For-Parts?query=W10374126
or here too and less money.
They both have videos on how to replace it and 800# tech help.
Call them before ordering to confirm this is the fix.
Best to you.
Maytag Maxima front load washer "master reset"?
To start, E01 and F06 means that your main central control board (CCU) and the motor control board (MCU) are not communicating with one another properly. The motor control board is located under the tub mounted to the floor of the washer. The CCU is mounted under the top panel of the washer and is the part with about 100 wires going into it. You'll want to remove the top panel and the lower front panel to check the wire connections and make sure they are all secure. If everything looks good, then you just have to somewhat guess which control board you want to replace first, either the MCU or the CCU. The problem is that there is no way to test and determine which part is faulty so it's just a guessing game. That's what makes this one of the worst errors to get. I generally replace the CCU first as that is the part that shakes around a lot more during spin and it's the first place that the power goes from the power cord if there is any fluctuation in power, so it makes since that this part fails more than the mcu.
There is no Master reset. The only thing you can do is unplug for 1 minute then plug back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Water will not enter drum
not sure bout ur error code but would check the water inlet valve and the water pressure switch
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
