Hi I have same problem - yes, I have switched off, and switched it back on, also unplugged power supply, left it for 24 hours , plug power supply back in, swithed printer on to receive the same eror message.
Has anyone sensible suggestions for a solution?
Thanks in advance Hi I have same problem - yes, I have switched off, and switched it back on, also unplugged power supply, left it for 24 hours , plug power supply back in, swithed printer on to receive the same eror message.
The panel on the printer instruct me to restart the printer. It has not use for a while because a ink cartridge needed to be purchase. I have attempted to install the ink but I can not get pass the message on the panel. I have done everything I possible could do (unplug, press menu, turned off, etc.). Please help me to get to the point where I can install the ink cartridge.The panel on the printer instruct me to restart the printer. It has not use for a while because a ink cartridge needed to be purchase. I have attempted to install the ink but I can not get pass the message on the panel. I have done everything I possible could do (unplug, press menu, turned off, etc.). Please help me to get to the point where I can install the ink cartridge.
You can't post conmments that contain an email address.
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn
...imaging drum cartridge. Turn the
printer off using the power switch on the left side. Wait 10 seconds,
turn the printer back on, and check if the error message...sensor
solenoid nip. Turn the printer off using the power switch on the left...
(English)
016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn
... Press Select ( ) to clear the error on
the printer. Reset the printer NVRAM: Press Menu. Press the...and then
press Select ( ). When Restart Printer appears, turn the printer off and
then back on...
(English)
KB Article
How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059
...Troubleshooting Guide for My Dell
3000cn-series / 3100cn Laser Printer ...available online for your Dell
3000cn/3100cn laser printer. The troubleshooting...printing, refer to
the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide...
(English)
This type of error code implies that you need to restart the printer
again. However, do check to see if toner cartridges are seated in the
proper position. Also ensure that they have been locked in. This is an
error commonly associated with the Dell 3100cn laser printer.
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Memory Upgrade for Dell Color Laser Printer
3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the
PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB
(non-removable) of Memory. You can upgrade your Dell Color Laser
Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system
has 1 socket to install Memory, already with 64 MB (non-removable)
standard Memory installed.
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
HOW DO I RESTART MY PRINTER
Thanks in advance
