The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Put the machine on a 90 degree wash with nothing in it, wait until it has filled and then pour three quarters of a cup of neat thick bleach into the soap drawer.
Put an old towel under the machine. The bleach will foam up and foam will come through the soap dispenser and all over the floor like a scene from a 1950's "The Blob" movie (The foam will also coat the entire inside of the machine as a result and kill any smelly bacteria).
Once the cycle has finished, throw 4 dishwasher tablets into the drum and put it onto ANOTHER 90 degree wash. At the end of these treatments, you should be a lot closer to a clean machine
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
Not sure if this is going to relax you but our Beko is exactly the same.
It went through months of only getting to about 60, then solved itself.The ONLY time it does is when it is plumbed in from the hot AND cold feeds. You CAN feed the source from hot supply but it tends to be too hot!!! Things I have tried;
Bottle of washing machine degreaser run through a full cycle. Put in via the detergent drawers.
Last ditch attempt but VERY risky to clothes unless you follow advice... Cilit Bang! The strongest Cilit cleaner via detergent drawers AND some in the tub with a ball. Run this on the 60 cycle, then do a second cycle and a third. Then put it on 90 and run it empty couple of times. Obviously think about clothes in immediate future! Once cleaned through I ran an empty washer with normal detergent in AND fairy liquid. Gets very bubbly so onoly a tiny amount. You can also take the drawers out an look down the inside.... be full of mouldy powder/liquid. At very least it stops any smells from your washed clothes when they've been left in the drum after washing!
Other than that DO NOT spend on engineer to come out. Waste of time / money.
Clear your filter. Remove detergent drawer and clean the drawer and its receptacle on the machice. Bung in 8 milton tablets in the drum and put it on the hottest longest wash you can and leave it run normally.
Run a short cold wash to flush the machine
Now put some nice smelling low foaming disinfectant in and repeat the hot wash cycle. This should sort it but may take repeated treatments. Lower the amount of softener and detergent you use as excess can build up and can cause this problem to come back. Additionally dont overload with really dirty cloths and if you do a wash with exceptionally dirty cloths then after you empty your machine put it on a shortest rinse cycle to purge and contaminated water that is left behind.
If all this fails you will need to have your machine serviced.
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
