When I start a washing program, the engine begins to rotate and a few seconds later stops, and the display shows ERRO. Only the hand-wash program works well. The sign contains only one R, not double. "The word ... (one R) is considered as profanity on Fixya. Please review your question and try again." Maybe EA0 the message ...hmm
SOURCE: Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
SOURCE: LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Testimonial: "Thanks!I've already tried &didn't work. As soon as water fills up, instead of start washing, it makes the high pitch sound and "LE" somes up.Oh No...!"
SOURCE: Need Manual for Electrolux EWT 13420 W - EWT 10420
These site carries the full line of Electrolux Manuals
http://userguides.50webs.com/manual.htm
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
