Question about Samsung ML-2510 Laser Printer
Samsung ml-2510 both lights flashing - Samsung ML-2510 Laser Printer
Posted by Y_aSk_Y on
5 Related Answers
Anonymous
SOURCE: Samsung ML-2510 both lights blinking fast
I noticed that the orange cancel button was jammed down. I couldn't prise it up, but was able to release it by tapping firmly the top of the printer near the button. As soon as it popped up - the buttons stopped flashing
Posted on Nov 10, 2007
Anonymous
  • 1605 Answers
SOURCE: my printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Posted on Apr 17, 2009
Anonymous
SOURCE: Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Posted on Apr 18, 2009
Anonymous
  • 71 Answers
SOURCE: I have a ML-2510, I
The green light blinking means that it is accepting or printing data.
But, the red light is for the error messages. This blinking means there is a toner problem. 1. remove toner cartridge from printer and gently shake to redistribute any that is left, or
2. You simply have to replace the toner cartridge with a new one - this one has been exhausted.
Posted on Jul 09, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Posted on Jan 30, 2010
Tone level for ml-2510
are the copes too light if so you will have to chqange the cartridge. either the life is over or the cart you have is bad.
Oct 07, 2014 | Samsung Office Equipment & Supplies
RED LIGHT KEEP BLINKING ON MY ML-2510 PRINTER IT STILL WORKS , WHY?
A red blinking light on a samsung printer will often indicate that your toner level is low. It will still continue to work until the toner fully runs out. This is Samsung's warning saying that you should think about changing your cartridge soon. I hope this helps.
Sep 08, 2011 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Installation Problem Windows Vista Home Premium
wellcome in fixya .com
please click on this link where u can find the driver of samsung ml-2519 for vista
Jul 29, 2009 | Samsung ML-2510 Laser Printer
I have a ML-2510, I turned it on and both the red light and green light flash constantly. Will not feed or print.
Jul 09, 2009 | Samsung ML-2510 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
Samsung ML-2510 will not print from MAC OS on Macbook
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
651 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
