Question about Eclipse Car Audio & Video
I need color codes for eclipse double din indash radio
Posted by Ramiro Rodriguez on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: double din radio doesn't fit in dash
i have a 2002 ford escape and i bought a double din radio and it did not fit and found out it is actually a din and 3/4 with out serious mods (cutting a bigger hole in dash) double din wont fit i bought a single din stereo and a din a 3/4 dash kit works fine
Posted on Jun 17, 2009
xxxxxx xxx
  • 5023 Answers
SOURCE: need code for 2000 mitsubishi eclipse radio
Mitsubishi codes are only available from the Main Dealer or a Radio Decoding Service.
They are not available for free as access is required to the original factory database ...which is not commercially available....Sorry
Posted on Jun 30, 2010
Anonymous
SOURCE: my kenwood double din radio
Hello, i´ve a auto radio Kenwood kdc-bt6544u, i´m more than happy with him. The other day morning i put the plate in the radio and it appears the word protect in the display, I´ve checked the speakers, remade the speakers connections and still appear the message. Can you please help me, what should i do? I shall now wait for your kindly feedback. Best regards Ricardo Fonseca
Posted on Jul 02, 2011
Ivgsoft Ivgsoft
  • 104 Answers
SOURCE: radio code for alpine radio model c33 din us bmw z3 al6bdut078086
Alpine BMW codes available online only here:
http://www.radionavicode.ivgsoft.com
Posted on Aug 15, 2011
MadMikeRS
  • 743 Answers
SOURCE: 2002 s10 xtreme blazer, Is
I do believe you can search through Crutchfield.com and in there is an explanation on din sizes and with a vehicle search you can see what size din yours should be.
You should have a double din if it is OEM. A single din is about 2" tall while a double is 4" tall.
There was also a DH (din and a half) found in early 80's to early 90's GM vehicles (and maybe other makes).
Posted on Sep 06, 2011
Where can I get a color-coded diagram of audio wiring?
Before you put power to this contact the manufacture of the unit for proper application so you don't short it out or start a fire.
Feb 04, 2016 | 2010 Chevrolet Chevrolet Malibu LTZ
Installation instruction
what vehicle are you putting it in, as if it was meant to be in the vehicle the wiring would be there already , if not forget it to much work and not much chance of getting it working properly anyway
Jun 01, 2015 | Ouku Double 2 Din Indash 7-Inch 2002 03 04...
I just bought a new kw-AVX740 radio and i have a 01 mustang and i don't really no how to install it
first and foremost you need to buy a car audio installation kit for your car model and year. Wal mart has some, but i think you may need to drive down to your local car audio shop and buy one from them if wal mart don't have them. Remove the old/factory radio. If an aftermarket radio is already installed then you may get lucky and find the harness already installed, but depending on what kind or radio it is( ex: DIN or Double DIN), but the specs for your radio is Double DIN(fat) so you may still need to buy the installation kit. Once you have the kit, everything is color coded, just match the wires and connect, then plug the harness after you have secured the wires. For a clean professional installation look, solder your wires(60/40 solder and soldering iron needed) and seal the connection with a heat shrink tube(audio shop carries the tube as well) and your good to go. I found you the install manual, just copy and paste(make sure all wires are connected with keys off the ignition until everything is good and connected)
http://resources.jvc.com/Resources/00/01/50/LVT2173-002A.pdf
Jul 14, 2011 | JVC Car Audio & Video
I am looking at bluetooth radios for my wife's chevy Venture (2005). I keep seeing Double DIN is this correct?
yes this vehicle has a double din radio. the old standard radios like most aftermarket are single din,double din refers to being double size of this.
Dec 13, 2010 | 2005 Chevrolet Venture
I have a 2001 grand jeep grand cherokee can i fit a double din radio in it
no, sorry. Info on aftermarket stuff for your car is here: http://www.modifiedlife.com/2001-jeep-grand-cherokee-car-radio-wiring-diagram/
If there was a double-din adapter, it would be listed with the other dash adapters in the right column below factory the wire colors.
Dec 03, 2010 | Car Audio & Video
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
What size after market in dash dvd can I put in 2003 spyder gs
your radio/dash opening DIN size is what they call double DIN, to get the right unit fopr this u will need to know if you have a Facory Infinity premium sound system, it makes a diff in the model f the in dash units, here is a link to a site that has a selection of in dash DVD players for your double DIN dash.
http://www.crutchfield.com/S-nkinM0jziRR/cgi-bin/autoinfo/autoinfo.asp?id=&vehicleid=14718&vb=Y&TypeCH=&lp=%2Fg%5F168550%2FIn%2Ddash%2DDVD%2DReceivers%2Ehtml%3Ftp%3D20217&sl=Y
Aug 11, 2009 | 2003 Mitsubishi Eclipse Spyder
Double din radio doesn't fit in dash
Jun 10, 2009 | 2003 Ford Escape
I nedd ddx8017 bypass code
I need a unlock code for the kenwood ddx8017 dvd player the unit has locked me out
Aug 20, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Car Audio & Video Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
