Computers & Internet Logo
Francy Villalobos Posted on Jan 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use the smart Hub screen keyboard - Smart Computers & Internet
mika
Level 3:
Master:
  • Master 469 Answers
  • Posted on Jan 06, 2017
mika
Master
Level 3:
Master:
Answers
469
Questions
0
Helped
224996
Points
2864
1helpful
What do I need to set up too a sharp smart tv?
Read the manual?
Google make model manual
Go to settings - Wifi and enter SSID and Password. That's it. Go to the Smart Hub and choose your Apps. A wireless keyboard makes things easier.
How to use the remote control keyboard when i using the smart hub in my tv
In my daily schedule was not conscious of abnormal wear to end and texture of the lid the screen looks extremely great to resist fingerprints. Mouse Pads Choosing The Best Pad For Your Computing Needs AmanStino
I bought a Samsung BD HDD Combo from a seller on facebook. I no longer have his contact details and I need to know his PIN number. How can I get around this?
Not sure if this will help
Reset
The Reset function initializes all downloaded
widgets, erases all user accounts and settings
from the product, and resets all Smart Hub settings
to the factory default settings. It then restarts
Smart Hub as if it were starting for the first time.
Your account, however, remains on the Smart Hub
server. To log into your account, enter your ID and
password on the Create Account screen.
To use the Reset function, follow these steps:
1. In the Settings menu, select Reset, and then
press the ENTER button.
The Reset screen appears.
2. Enter the your Security password. This is the
password you entered if you set up a BD or
DVD Parental rating (See pages 51~52). If you
did not, enter 0000.
Samsung BD D8900M User Manual
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Logitech k400r keyboard problem
I've never seen a smart TV setup, but here's a couple of thoughts I had:
Has the keyboard worked with the smart TV yet? It's possible you haven't plugged in the dongle to the USB port, if it's a wireless keyboard. Then again, you might need to use an on-screen keyboard for a setup entry.
How do i change the country on the samsung hub on samsung smart tv model ue46f6400.
As found on AVForums:
  1. Select HDMI1 as source.
  2. press Menu on your original remote.
  3. Go to System and select Setup.
  4. Enter your Pin, by default it is 0000.
  5. Select your on-screen language, go to the right arrow and press Enter on your remote.
  6. In the following screen DO NOT change country and go to the next screen.
  7. in my case, I now get Smart Hub agreements. Press the following buttons on your remote quickly: Mute, Return, Volume Up, Channel Up, Mute. After a second a advanced menu will open.
  8. Select the country you wish Smart Hub to be in en pressEnter on your remote.
  9. A valid zipcode is required for that country. Enter it in this screen. Easy to find one with Google/ Google Maps. PressEnter on your remote.
  10. You now get the user agreement, you may want to read this. When done, check the boxes and go for next. Do the same with the rest of user agreements.
  11. In my case, I was done after these steps.
Now when you go to Smart Hub, it will load all the apps that are default for that zipcode you punched in earlier. It may take a while to download them.
Some apps are restricted per area/ region. This requires some more technical knowledge about DNS and VPN services.
Worked for me on my Samsung UE46F6500
3helpful
What do you have to reset when you change the bulb
Press the Menu button on the HTS remote control and then move to Setup and press enter on Reset.Launch Smart Hub from the home menu or by pressing the Smart Hub button on your HTS remote. Press the Blue D button to bring up Account Management and then move to Reset and press enter on your remote. Enter the BD or DVD parental rating password; if you did not setup a password enter 0000.
Smart Hub automatically resets, the screen may go black and then re-appear. In a few moments the re-initialization procedure starts and the Terms of Service agreement is displayed, follow the on screen prompts to complete installation.
2helpful
How do i print screen using "smart office keyboard
Hi there!
Just press the print screen button located in the upper right of your keyboard. (Prtsc key) and open the paint program (located in accessories folder). Once you open a new file, paste it from there or press ctrl key+ V key to paste. And then you can print it or save it to your computer.
This should solve your problem.
Print screen will not work on my EZ-8000 Smart Office Keyboard
Unfortunately on almost all new keyboards the print screen will not just print out a page of text. What print screen does now is that if you press the print screen button an image of what you are seeing will be copied to the clipboard so that you can just go into any program and click paste and you will get the monitor display that was visible. I hope this helps.
Scott
Top Smart Computers & Internet Experts
vince
Paul Bade
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
