Does MA5800 support the Multicast? - Computers & Internet
Posted by Monica on
hone zhang
    Habit-Forming:
    New Friend:
  • 57 Answers
Yes, it supports Layer 3 multicast networking, also supports IPv4 PIM SSM.
Protocol Independent Multicast-Source-Specific Multicast (PIM-SSM) enables a user host to rapidly join a multicast group if the user knows a multicast source address. PIM-SSM sets up a shortest path tree (SPT) from a multicast source to a multicast group, while PIM-SM uses rendezvous points (RPs) to set rendezvous point trees (RPTs). Therefore, PIM-SSM implements a more rapid join function than PIM-SM.
Different from the any-source multicast (ASM) model, the SSM model does not need to maintain an RP, construct an RPT, or register a multicast source.
The SSM model is based on PIM-SM and IGMPv3. The procedure for setting up a multicast forwarding tree on a PIM-SSM network is similar to the procedure for setting up an SPT on a PIM-SM network. The receiver's DR, which knows the multicast source address, sends Join messages directly to the source so that multicast data streams can be sent to the receiver's designated router (DR).
http://www.thunder-link.com/HUAWEI-MA5800-X7_p928.html
Posted on Jan 06, 2017
Does the Huawei MA5800 X15 support active/standby mode?
The Huawei MA5800 does not support active/standby mode, but only load sharing mode. The MA5800 has a distributed architecture. When two control boards are configured, the active and standby control boards carry services at the same time to effectively utilize the bandwidth of two control boards. Huawei MA5800 X15
Sep 30, 2018 | Huawei Computers & Internet
How many 10 GE ports are there in the Huawei MA5800?
Hi,there!
Huawei MA5800 series are next generation, 40G capacity Optical line Terminal (OLT).It support 8 x 10 GE SFP+ interface or 8 x GE SFP/eSFP interface.
Dec 26, 2017 | GE Computers & Internet
Does Huawei MA5800 have new typical New Hardware Board?
Yes,Huawei MA5800 do have new typical New Hardware Board. H901TWED, 8-port symmetric 10G GPON interface board, it works together with the Huawei ONT to provide 10G GPON access services.
Dec 15, 2017 | Huawei Computers & Internet
What's the difference between Huawei 16-port GPSF and Huawei 16-port GPHF?
There are two main difference:
1, different MAX number of MAC address supported:
H901GPSF: 16384
H901GPHF: 131072
2, 1588v2 procotol
GPHF support this protocol, GPSF cannot support.
3, Queue scheduling hierarchy
GPHF 4-level HQoS, GPSF 2-hierarchical HQoS
Actually, GPSF is more popular among people, but if you have high requirement for the above points, then you can consider GPHF for you MA5800 X7 or MA5800 X17.
Jul 28, 2017 | Huawei Computers & Internet
Does MA5600T series GPON board can configure in MA5800 series equipment?
No, it can't. Huawei GPBD, Huawei GPFD GPON boards can be configured in Huawei MA5680T, Huawei MA5683T, Huawei MA5608T series equipment, but can not configure in Huawei MA5800 series equipment.
Jul 20, 2017 | Computers & Internet
How do I turn on muticast
In most cases "multicast" is on in devices. For example, that's how your Windows computer finds "other devices" on the network (through UPnP). However if your task requires more like "global presence", it depends on devices that build your network - switches, routers, firewalls, WiFi, etc. Some of them may support natively, some may require special configuration, and some may not support multicast at all. Then, when it gets bigger, it comes to the "multicast protocols" (for example, IGMP, PIM, etc.).
What is your goal? Depending on that you may need to discover your options.
Good luck,
Michael Shavrov / Cisco CCNP, CCDP, CCSP, CCSP
www.headsetadapter.com
https://en.wikipedia.org/wiki/IP_multicast
May 17, 2016 | Computers & Internet
Multicast
Please open router page and go to advanced just like in this emulator.
http://support.dlink.com/emulators/wbr2310/adv_network.htm
Jul 25, 2014 | D-Link Computers & Internet
How enable multicast traffic on RVS4000?
1.Your router is set up for multicast automatically
2.Look at the QOS or traffic shaping.
Apr 19, 2010 | Linksys RVS4000 Router
Network prolem
For
broadcast traffic to use a large portion of your bandwidth you need 2
conditions:
* A very high rate of broadcasts per second
* Large broadcast packets
* Low bandwidth
Aug 13, 2009 | Cisco Catalyst 3560 24-Port Ethernet...
Computers & Internet Logo
149 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
