For starters, do as cold reboot. turn the router off, unplug it & remove the back up battery if so equiped(should be simple, if not skip it) Leave off for 2 minutes. Then turn it back on. Then do the same to your tv. Reenter the router on your tv. Good luck.
Netgear: 192.168.1.1 user: admin password: password or 1234
Go to Advance > Default DMZ Server and enter the computers IP that needs VPN access. This will bypass routers NAT / Firewall, and allow all network ports access.
It shows where the factory reset pinhole is. And then further on it describes the reset process: Restoring the Default Password and Configuration Settings
the reset button is located on the back of the router..its a small hole where you can poke a ballpen or a paperclip. press and hold for about 10 sec for hard reset...
