Televison & Video Logo
Question about Pioneer Televison & Video
I have a pioneer pro 151 TV having issues turning TV on I get a blue light blinking 9 times
Posted by mark scanapieco on
Larry
  • Pioneer Master
  • 4,632 Answers
This code is caused by the main (A) board being defective. It's generally the CPU that is bad, this won't be a part you can replace, the board will need to be replaced, finding a board will be expensive and hard to find.
Posted on Jul 04, 2022
    Top Expert:
  • Pioneer Master
  • 76,851 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 05, 2017
  • Larry Jul 04, 2022
    More USELESS information like normal, it's always the same message,http://electronicshelponline.blogspot.co... is useless. Try offering some actual help for ONCE!!!!!!
Pioneer pro 151 tv will not come on uless unplugged for a long time 9 blue light flashing
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Power failure
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes and details about many popular brand TVs are given.
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Thomas
Pioneer Pro-111FD does not power up and blue light keeps blinking 8 times
8 times blinks denotes a cooling fan failure. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Reset pioneer tv
I rearranged furniture in my living room, picking up my pro-151fd elite, plugged it in to have no power, tried everything I could think of including an overnight reset. Thought of what could be the common denominator with most of the issues that people have, it's that they picked it up, felt under the front left and turned the tv on. The switch is not labeled, is part of a sqaure protrusion at the very bottom of the tv, 1" to the right of the "Pioneer" label, hope this helps someone who just has a dead tv without the blue flashing lights.
My tv will turn off by itself every 30 mins and has a blue light that blinks 12 times! how do i fix this problem?
yr sleep program is on. Find this in the menu and turn off. It is also on yr remote, u can turn it of from that just take yr time and work out which is the sleep mode button and click until the screen shows off or something similar. cheers
2answers
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
