Cooktops Logo
Question about Cooktops
Where from can I buy igniter for se64 model gas hob
Posted by Haq nawaz on
  • Marvin
    Marvin Jan 05, 2017
    What is a gas hob?
Jorge Rendon
  • 5,541 Answers
Posted on Jan 05, 2017
1helpful
Flame leaking under lower ring. Common?
no it is a problem with the hob
consider this
as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem
If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it
if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 • Cooktops
1helpful
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
3answers
Cannot ignite central gas ring on smeg 5-ring kitchen hob
I had a similar problem on a different gas range but your problem seems the same as mine was.
I examined the underside of the burner and saw a little 'flash' left from the casting process and I filed it off. This made the problem worse; it wouldn't light at all anymore.
I tried the opposite, blocking off the burner channel from the gas feed pipe to the spark gap; problem solved. It hasn't had a hiccough since.
I can only imagine that the flow of gas toward the spark gap was so strong, the gas was blowing itself out.
Not knowing exactly how the underside of your burner looks or how the gas is partially diverted to the spark gap but I drilled a small hole in the casting, inserted a length of copper wire (the gauge used in house wiring), then 'tuned' the flow by clipping part of the wire off and trying it. It might have taken all of 15 minutes to correct the annoying problem.
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Stuck auto ignition
try easing each knob upwards a bit.
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
2answers
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Top Cooktops Experts
Marvin
Marvin
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
