Question about Tablets & eReaders
Kindle fire screen shows horizontal lines
How can i remove horizontal lines in my kindle fire's screen
Posted by R. Banks on
Marvin
    Top Expert:
  • Tablets & eR... Master
  • 85,239 Answers
The tablet has a failure in the circuit board for the display, the cheapest thing to do is replace it.
Posted on Jan 05, 2017
I am having problems with two of my Kindles: 1. Kindle fire 8, can't get on line and 2.Kindle tablet is jumping in and out of puzzle games.
Hello
Follow these steps to get online on Kindle fire 8:
1.Swipe down from the top of the screen to show Quick Settings, and then tap Wireless.
2.Verify that Airplane Mode is off.
3.Next to Wi-Fi, tap on.
4.Tap a network to connect to it.
For any help visit us: Kindle Fire Support
How to remove preinstalled apps from kindle Fire?
Hello Vin, I'm the also one who are using Kindle fire device from last two years and i also remove these pre-installed apps from my device by the help of support and help team of kindle. but you can remove these apps without taking help from them, so you can try these points;
From the "Home" screen, open "Settings".
Choose "Apps & Games".
Select "Manage All Applications".
Swipe over to the right to show "All" apps.
Select the app you wish to remove, then select "Uninstall".
If you face any trouble while removing these apps then you can contact to Kindle Support and Help team by dialing there toll free number which is 1-800-942-6509, they can easily fix the issue in very minimal time.43c00a37-b9c5-43c5-a968-778d62c5802f.jpg
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
1helpful
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Forgot password to my kindle fire. How do I reset
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
2answers
The screen on my Amazon Kindle 3G is partially white and partially black with white lines running through it. It has been charged but does not respond when I turn it on. Do you think it is worth fix
It's broken :(
There are companies who will replace the screen for about the same price as a brand new Kindle BASIC. personally I would suggest:
- buy a new Kindle BASIC for 59gbp;
or
- download any of the FREE kindle apps and just finish your library reads for free whilst you look around for a replacement.
If you want a TABLET rather than a eReader remember ANY tablet will download the free Kindle app so you can read your books on a Fire or a ASUS or a NEXUS or a iPad or anything really :)
Good luck.
2answers
New kindle 3 . screen has frozen.
Amazon might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at Kindle 3 Repair and there is a guide that shows you how to put in the part at Kindle Repair Guide.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
