Internet disconnecting abruptly
Hi i have just bought toshiba laptop.The internet gets disconnected abruptly after 30 Min's and afterwards it does not get connected for couple of hours so i leave it idle and reset the modem,the router ,the system but in vain.
the OS i am using is WIN Vista(home).After few hrs it permits me and again it shuts me off.......please help me
Posted by pavsankar on
Anonymous
  • 51 Answers
Check your configuration in the router/modem for idle time and also connection type(on demand/always on/manual)
Posted on Feb 12, 2008
Laptop pc won't come on
Hi Jason, disconnect your laptop from the power source, take the plug out of the laptop also, remove your battery. hold down your power button for about 15 to 30 seconds, don't replace your battery yet, plug your cord back into the computer and then the wall, turn it on, if it comes on place your battery back in it.
Jan 11, 2015 | Toshiba Computers & Internet
Broadband connection problems
Hi, to fix the problem, here are instructions to get the right Broadband Internet connection. From the "Start" menu, select to open the Control Panel. Next click on the Network and Internet category, select the Network and Sharing Center. In the Tasks ( left, column), select to open the ("Connect to Network"), "Setup a connection or network." In the next window there will be a choice of "Options" to have the connection setup; select the type of connection (Broadband) and use the "Wizard, by click "Next." Follow all instructions afterward, and "restart" the computer. "Rating the solution is appreciated, if it helped?" Thanks!
Feb 22, 2010 | Toshiba Satellite M55-S135 Notebook
I bought a toshiba from a person I have tried to
well this a normal security passw, but you can clear-it . with a little time.
1st. take the keyboard out.
2nd. check for a small battery, inside.
3rd. disconnect-it and wait 10 min.
4rd connect-it and check again.
Remember this : Do this with battery out and external power supply disconnected. And all user setting is cleared. Must config. the time and a date again
Oct 31, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite a205-s5804 laptop will not start
Hi, there are a couple of possibilities:
1. If you are able to start the laptop on battery then the dc connector on the motherboard may be broken or have come loose, in which case take it in for repair.
2. The power switch may be broken, again take it in for repair.
3. Tip of the trade: Disconnect the battery and plug in the charger, see if it will switch on. If not then put the battery back in with the mains still plugged in and see whether it springs back to life.
4. Tip of the trade 2: Leave well alone for a couple of days without any battery or power connected then plug back in and see if it will switch on.
Removing the BIOS memory, don't know where you saw that but not recommended at all unless you want to render your laptop completely useless. Don't attempt to strip down unless you are technically experienced with disassembling a laptop.
Jun 10, 2009 | Toshiba Satellite A15-S127 Notebook
TOSHIBA LAPTOP WIFI PROBLEM
Hi , It seems your Wifi is not having problem but the issue lies with the internet connectivity , What browser you try to use , Try using mozilla and then let me know
Jan 14, 2009 | Toshiba Satellite P15-S479 Notebook
Re:ISlow nternet in my Toshiba Satellite Laptop
You need to secure your router. Your router might be unsecured and your neighbors can connect to it without you knowing and you get to share the bandwidth of your internet to them which causes it to slow down. Contact your router manufacturer and have them assist you securing it. Others tend to connect to unsecured network and have free internet.
Hope this helps.
Sep 06, 2008 | Toshiba Satellite A100-S8111TD Notebook
Power on password for toshiba satellite m30-107
You can by shorting the CMOS/BIOS battery connector for 30 sec's with a resister pack (2.4 KOhms), but if you don't have any PC repair experience, don't try it!
"You can blow the motherboard if you get it wrong.."
I suggest you take it to a Toshiba repair shop, it will cost about $100 to have them do it for you.
May 08, 2008 | Toshiba Satellite M30 Notebook
Computers & Internet Logo
154 people viewed this question
Ekse
Marvin
Marvin
