These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
i have the LC-26GA4U LCD TV & mine has the exact same problem. I brought it to an authorized sharp tv repair shop it turns out its the LCD panel. the panel costs $1700 & with labor installed it comes to $2055.43. almost exactly what I paid for the tv 2 years ago. good luck. Mike
