SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
SOURCE: Vaporizer That Works?
Thanks MStout
We use our Vicks vaporizer infrequently and lost the instructions. We substituted Morton (iodized ) salt. It vaporizes great now. It's so helpful to have an online resource like this.
SOURCE: Vaporizer Instructions
Try this: It should let you download a PDF of the instructions.
http://209.85.173.132/search?q=cache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%3FProductManualAction%3DrenderProductManualById%26ProductManualId%3D5faaee9ab20669a0a26a9fb6e6bb99f8+Vicks+Vaporizer+instructions&cd=44&hl=en&ct=clnk&gl=us
SOURCE: I just bought vicks warm steam vaporizer 1.5
Try this: It lets me download a PDF of the Instructions.
SOURCE: My vaporizer is barely putting out any steam...is
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
