i try to get online with a wired connection and it just says a dns error 80710102 what dose that mean how can you fix thati try to get online with a wired connection and it just says a dns error 80710102 what dose that mean how can you fix that
I have the same problem with the DNS and I cant repair to get a new IP address. Im really not sure how I should go about the setup on the ps3. Right now I have it set up with just my pc and a ethernet cable to the ps3. I have a PC card and when asking if I can connect my ps3 they said I can do it and people are doing it. Can anyone help with step by step setup??I have the same problem with the DNS and I cant repair to get a new IP address. Im really not sure how I should go about the setup on the ps3. Right now I have it set up with just my pc and a ethernet cable to the ps3. I have a PC card and when asking if I can connect my ps3 they said I can do it and people are doing it. Can anyone help with step by step setup??
You can't post conmments that contain an email address.
It
seems like the DNS error is generally caused by problems on your ISP's
end of the network, but that doesn't mean you can't have a crack at
fixing it yourself.
Under your network connection settings try changing the DNS servers to the following numbers (they're free by the way)
Primary DNS 208.67.222.222
Secondary DNS 208.67.220.220
Also, try disabling media server connection as well. These simple steps should, in 90% of cases, fix the problem.
"When a DNS server error occurs, your PS3
will not be able to connect to your home network. This means you cannot
take advantage of the many online features that the Playstation 3 has.
There is no real reason why certain DNS server errors occur, but fixing
them should be simple."
When a DNS server error occurs, your Playstation 3
is it an older game?
if it is then its because the website group hosting that game has stopped because not enough people play to keep the dns system up
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
