Question about Samsung Heating & Cooling
My Samsung cassette air conditioners showing green light instead of blue what it's meant
Posted on May 25, 2020
SOURCE: indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Posted on Apr 09, 2010
SOURCE: when i start the a/c indoor unit working and after
Green blinks indicate communication to outdoor, but red light indicates communication problem. Check PCB.
Posted on Oct 27, 2011
SOURCE: carrier cassette ac is blinking
Replace your indoor coil thermistor....
Posted on Dec 06, 2011
SOURCE: Hitachi indoor unit showing red light blinking in nine times
relay must be change,
or the indoor unit board to be change
Posted on Nov 15, 2012
SOURCE: Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Posted on Jun 06, 2015
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
