Question about Aircrafts
What happens if a private Cessna 172 pilot tries to land at big airports like JFK or O'Hair when there is no emergency?
I have never seen small planes at these airports. Are they not allowed there or is it just expensive that they can't afford it? What happens if a 20 year old PPL only pilot wants to land at JFK or O'Hair? Will they ask him to go away? Cessna pilot "JFK, This is November Three Zero Five Romeo. Is runway 22R or 22L available?" ATC "Is there an emergency?" Cessna pilot "No. We are traveling from Michigan to New York and we want to land at your airport. November Three Zero Five Romeo" What will happen next? Will they ask him to go away?
Posted by Lewis Mullins on
keylempi
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 38 Answers
It's quite permissible to do so, however a general aviation pilot in a low performance plane should be ready for fast instructions and quite a bit of maneuvering to stay out of the way. The best time to do it would be at night. Here's a youtube video of one doing it. https://www.youtube.com/watch?v=KKvWn317tpU
Posted on Feb 03, 2017
Do you need a type rating to fly your own Bitchcraft 1900 or Cessna CJ2?
The type rating is required in aircraft that need additional training. It is a safety of flight issue not a for hire issue.
Jan 04, 2017 | Aircrafts
Is it worth to buy a 30 year old Cessna to build time?
Older planes are usually very good purchases, IF they have been well maintained over the years. Airplanes have to be inspected annually by an A&P mechanic with an Inspection Authorization so they are usually very well maintained. Any purchase should include having an A&P mechanic review the airframe and engine logs and evaluation of the plane, including looking at how many hours the engine has since overhaul and checking compression. I had a 1966 Cherokee 140 for several years and finally sold it when I bought my current Experimental aircraft (a BD-4). It helps a LOT if you can get an A&P license and maintain you own plane though.
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Is it common that small local airports don't have radars?
It is very common for small airports not to have a control tower, radar, or communications equipment. There are very well developed procedures for "uncontrolled airports". There is a standard traffic pattern that aircraft fly at almost all airports (consisting of a downwind, base, final, and upwind leg) and there are specific radio calls that are supposed to be made at certain points in the pattern. Most airports have a fixed base operator to supply fuel and services. They often monitor the common traffic frequency and supply some info to pilots about wind direction and runway in use. There's also a specific way to enter the pattern - usually at a 45 degree of the downwind leg, Yes it's possible for aircraft to collide and it happens several times a year - usually when a low wing airplane is above a high wing airplane in the pattern. Neither can see the other so occasionally that can happen.
Do domestic flights fly over foreign airspace?
Technically is you are flying domestic you are not flying over foreign airspace. If flying IFR you must file one. Needless to say when filing a flight plan you must decalre if you are domestic of international flight.
Where do you land if there is an emergency during a trans-atlantic flight?
You're stuck with a water landing (ditching). Hopefully at altitude the pilot can see a ship and make the landing in the vicinity of the ship for quick rescue. It so rare for a plane to lose power to all engines though that you should never hear of such an incident. Depending on the route, however, Bermuda may be within gliding distance.
How is a pilot supposed to find out their distance in miles from an airport they're landing at?
Using the old (pre GPS) method you would use the sectional and plotter (aviation ruler) and measure the distance. Using a GPS you can usually turn on distance rings on the screen or if you have the airport selected as destination you can read it right off the screen. If it's your home base you should learn the landmarks and their distances from the airport. In the Miami area, there are so many airports and landmarks, if you're flying there, during your preflight preps you should measure out distances to some landmarks that you plan to pass over and mark them on the chart or flight log.
Scared of plane crash?
The safest time to fly is after such an incident because all pilots are double checking themselves to make sure it doesn't happen to them.
Got a hypothetical for aircraft pilot's (Small planes).?
I suspect that the idea of max climb plus glide is not a new one, and that, if it really were cost-effective on fuel, we would know about it.
Aircrafts Logo
112 people viewed this question
Top Aircrafts Experts
STEVE SPAM REMOVER
James M Knox
James M Knox
Level 1 Expert
Robert Wood
Robert Wood
Are you an Aircraft Expert? Answer questions, earn points and help others
