Question about Aircrafts
How do you start a plane?
I m talking about the big ones, the ones you take on your vacation to a warm place. Does it have a key like a car or something? If not, how do you start it? Can someone just break into a plane and start it? Or how does that work?
Posted by Harold Lilly on
zbuilder801
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
The best and safest way to start an airplane in the USA is by learning from a legal FAA instructor.
Posted on Mar 26, 2018
masud
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 582 Answers
Technically anyone could get in and start a big jet aircraft,
Posted on Apr 10, 2017
  • Aerosputnik Apr 15, 2017
    It seems that all you need to do to get a 'Master' rating on fixya is to copy and post the first line of someone else's reply. What a phoney!
  • zbuilder801 Mar 26, 2018
Aerosputnik
    Habit-Forming:
    Scholar:
  • 48 Answers
Technically anyone could get in and start a big jet aircraft, but it would have to be pointing in the right direction. Getting a large transport jet going is allot more complicated than just starting the engines. The whole aircraft has a multitude of systems that have to be brought on line even before the start is selected. Failure to do so would have the computers on board sulk until you said good morning to them. The first operation, thus, is to 'power-up' the aircraft, this means to establish electrical power. This can be done in two ways, one being establishing a ground power unit and secondly, the aircraft's own auxiliary power unit, which is normally a little jet engine in the tail of the aircraft. The APU as it's called (auxiliary power unit) will also supply air pressure for cabin air conditioning and to the air starter units used to spin the main engine turbines at high speed to start the main engines, when commanded to do so. This is why the air-conditioning temporarily goes off when the engines are starting, because the APU cannot supply both engine start air and conditioning air at the same time.
After electrical power has been established, the on-board computers will come to life. Some computers are in their own little world and control things that are fully automatic, you only hear from them if they detect a defect in their own self test. Other computers are in pairs and threes, they monitor each other and alert the pilots and engineers via other computers if any detects faults in the others. There are two or three inertial navigation systems that are driven by lazar light. In each unit there are at least three lazars in different orientation. These units can detect the slightest movement and calculate the position of the aircraft by adding that movement to the aircraft's current position. The IRS units are very - very clever since they measure the movement by measuring the shift in the light spectrum when the aircraft moves. Since they measure movement, they have to know the speed the world spins at and the speed of the earth through space, to deduct that from the small movement on the aircraft in order to calculate the position. Allowing the IRS units to come on line is essential and must be done before main engine start. The aircraft must be completely stationary for this to happen.
After all that has been done the main navigation computers are programed for the route to be flown and with other information. The Flight management computers (as they are called on some aircraft) can also acquire their own information, like how much fuel is on board, and in flight the airspeed of the aircraft the angle at which the aircraft is at and from that it will calculate the weight of the aircraft.
So when all the systems are up and running and the computers have done their thing and have been programmed where required we can carry out all the other checks, switch on the galley power and call for a cup of tea and when we have drunk that we are nearly ready to start the main engines.
When ready to start the main engines the air system has to be re-configured to enable the starters to operate, following that the normal procedure is to place the engine start switch in the auto start position, where all the starting functions are carried out automatically. Both pilots monitor the engine start as sometimes things can go wrong like a hung start or a hot start. These sort of malfunctions can seriously damage a multi-multi million dollar engine in a flash and no pilot would want to be responsible for that. As the engine spins up to speed, at a predetermined percentage RPM the captain will select the fuel switch to the run position which will allow the fuel to be injected into the engine for light-up. Following a normal start the air system is then reconfigured once more as part of the after start check list, along with other post start items.
All in all what I'm trying to say is that it is a complicated procedure and not just about turning a key like a car. So if you were to board a dead aircraft on the tarmac and turn the start switch nothing would happen.
So what if the engineer wanted to run an engine for an engine test, would he have to follow the same procedure? Well, apart from loading the flight data into the flight computer, he would have to do everything else, if only to prevent all sorts of warnings that would occur trying to short cut the procedure, since the only warnings he would wish to see is anything that is relevant to the engine start, otherwise engine starting and running warnings may well be disguised by other more insignificant malfunctions. Hope this has been helpful.
Posted on Apr 03, 2017
What happens if a private Cessna 172 pilot tries to land at big airports like JFK or O'Hair when there is no emergency?
It's quite permissible to do so, however a general aviation pilot in a low performance plane should be ready for fast instructions and quite a bit of maneuvering to stay out of the way. The best time to do it would be at night. Here's a youtube video of one doing it. https://www.youtube.com/watch?v=KKvWn317tpU
Jan 04, 2017 | Aircrafts
Is it worth to buy a 30 year old Cessna to build time?
Older planes are usually very good purchases, IF they have been well maintained over the years. Airplanes have to be inspected annually by an A&P mechanic with an Inspection Authorization so they are usually very well maintained. Any purchase should include having an A&P mechanic review the airframe and engine logs and evaluation of the plane, including looking at how many hours the engine has since overhaul and checking compression. I had a 1966 Cherokee 140 for several years and finally sold it when I bought my current Experimental aircraft (a BD-4). It helps a LOT if you can get an A&P license and maintain you own plane though.
Is there a speed limit for airplanes?
There are some speed limits for certain types of airspace. Airliners are always in contact with air traffic control and in order to keep the required separation of aircraft sometimes the controllers will ask the pilot to maintain an airspeed. More than likely you experienced a slowdown while your plane was beginning an approach, During approach controllers have to maintain specific spacing between aircraft and often must slow them down behind slower aircraft. Your plane very likely was slowing down from approx 570 knots to 250 knots or less for the approach.
Why do air traffic controllers make bank?
From a pilot perspective, the pilot is ultimately responsible for all operation of the aircraft. This includes following all the instructions of an air traffic controller who often gives their radio commands so fast a stenographer couldn't keep up with it. Often an unbelievable amount of stress, but we can always ask them to repeat slower - though they frequently get a little sarcastic when you ask. Controllers, on the other hand, are responsible for sometimes dozens of aircraft in their sectors and many of them are not talking to the controller. I can imagine an equally huge stress trying to keep the planes that are talking to a controller away from the ones who aren't talking to the controller. So I'd call it fairly even.
Is flying during a snow shower dangerous? I am going back to Los Angeles from Denver on Wednesday, but there is a snow shower.?
As long as the plane is equipped for icing, which all airlines are, there is not really any added danger to flying in snow. Braking on landing may be affected if there's any accumulation but they keep close track on braking ability as each plane lands at the airport. Snow won't affect the way the plane flies as long as the wings are clear of snow on takeoff.
Got a hypothetical for aircraft pilot's (Small planes).?
I suspect that the idea of max climb plus glide is not a new one, and that, if it really were cost-effective on fuel, we would know about it.
Why no whole-plane parachute system on commercial flights?
Aircraft too heavy. Weight is extremely valuable/expensive and the weight of a parachute system would be too heavy and costly, sacrificing room for paying passengers.
Aircrafts Logo
240 people viewed this question
Top Aircrafts Experts
WATCHING YOU
Andrew Taylor
Andrew Taylor
Robert Wood
Robert Wood
Are you an Aircraft Expert? Answer questions, earn points and help others
