Question about Aircrafts
Is VFR with night vision goggles at night dangerous for civilian pilots?
When there is no ILS and it is too dark to see the small local airfield at night, can a cessna pilot use his night visions to land there?
Posted by Michele Tinkham on
O.Rojas
    New Friend:
  • 11 Answers
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Posted on Apr 23, 2017
Can a billionair own a small local airport and become a owner of a charter airline, chief pilot and airport police chief all by himself?
He would be stretching himself too thin to do it all at once. Airport police chief would require all his time spent on the ground, so being a pilot is possible, it would be impractical.
Jan 04, 2017 | Aircrafts
Is it illegal for a PPL only pilot to make an ILS landing?
It is not only ******* for a VFR only pilot to fly in the IFR system, it is also potentially very dangerous. Even many IFR rated pilots are killed each year from spatial disorientation. IF you are on a straight in approach to a runway with a localizer or ILS and just tune it in and fly the ILS I don't think that's an issue.
Why can t commercial airplanes use electronic view screens, like on Star Trek?
Modern Jet airliners already have electronic screens that depict the ground, the sky, maps, terrain and many more things, They are known as "Glass Cockpit" aircraft. These aircraft can land in Zero visibility fully automatically without the pilots having to see out of the window at all, just viewing the screens. The problems are in training of the flight crews. Full automated approaches and landings are far more exacting on the flight crew than a normal visual landing and crews have to be specially trained and certified to do them. The thought that on an automatic landing the pilots just sit there and do nothing is far from reality. The procedure is one of intense concentration and if the aircraft so much a twitches the pilots will abandon the approach, they have to watch everything. Training flight crews is a very expensive business and an international operator would have to have about nine crews for just one aircraft. Training those crews to operate with just view screens would blow the training budget out the bank. No matter how cleaver these modern jets are the fastest computer on board is still the one between the pilots ears and using all his senses and especially sight through a window will be with us for some time.
What happens if a private Cessna 172 pilot tries to land at big airports like JFK or O'Hair when there is no emergency?
It's quite permissible to do so, however a general aviation pilot in a low performance plane should be ready for fast instructions and quite a bit of maneuvering to stay out of the way. The best time to do it would be at night. Here's a youtube video of one doing it. https://www.youtube.com/watch?v=KKvWn317tpU
Is it common that small local airports don't have radars?
It is very common for small airports not to have a control tower, radar, or communications equipment. There are very well developed procedures for "uncontrolled airports". There is a standard traffic pattern that aircraft fly at almost all airports (consisting of a downwind, base, final, and upwind leg) and there are specific radio calls that are supposed to be made at certain points in the pattern. Most airports have a fixed base operator to supply fuel and services. They often monitor the common traffic frequency and supply some info to pilots about wind direction and runway in use. There's also a specific way to enter the pattern - usually at a 45 degree of the downwind leg, Yes it's possible for aircraft to collide and it happens several times a year - usually when a low wing airplane is above a high wing airplane in the pattern. Neither can see the other so occasionally that can happen.
Is there a law that says ex-felons can't work as commercial pilots?
Its a business deal. You could contract for a fixed minimum period of time.
Is manual CAT 3 landing possible?
Pilot can do anything he judges best for his flight.
How can i get my pilots license?
Go to your local airport and talk with an instructor. That doesn't cost anything and they'll be happy to answer any of your questions. You can go for a sport pilot license first because it's the quickest cheapest way to get in the air. Then if you "catch the flying bug" you can progress to a private pilot certificate.
Can military fighter jets use JET - A fuel?
They can use almost any jet fuel on a short term. For longer term use there is usually an adjustment required on the fuel controller.
Why can't a DC-10 fly without a flight engineer?
no but the flight engineer moniters fuel and electrical use hydraulic levels and apu operation
Aircrafts Logo
136 people viewed this question
Top Aircrafts Experts
Lawrence Oravetz
Eric
john h
Are you an Aircraft Expert? Answer questions, earn points and help others
