Question about Epson LQ-2180 Matrix Printer
Custom size paper on xp
How can i set custom size paper in lq 2180 if os is window xp, i can do it if it is windows 98 but how about windows xp is there a solution to this?
Posted by trent0774 on
  • supratna Jul 19, 2008
    i can't custom my LQ-2180 for 1/2 letter paper. i use win xp operating system
Mark Doyle
    Novelist:
  • 148 Answers
When you are in the page go to file, then print setup then go to advanced and it will let you do manuel adjustments or custom paper sizes. Depending on your printer you can also go to page setup and it will also give you page options..Be mucho blessed...Mark
Posted on Jun 27, 2008
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
My lq 2180 printer is not aligned properly.printing starts 2 to 3 inches from start of page.jump in every next page is increased by half inch.kindly guide Thanks
Dear user,
please check the paper size and the procedure is below.
open printer properties and then go to the printing preferences and then there slect there appropriate paper size according to your paper being used in printer.
hopefully it will work perfect.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
May 19, 2009 | Epson LQ-2090 Matrix Printer
I can't install on vista
i have a problem that i can't installing the wipro lq dsi 5235 dot matrix drivers in windows vista os
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-1170 ESC/P2 can't running in windows 98
You need a compatible driver to link the printer. Check online for driver compatability with older OS.
Feb 13, 2009 | Epson LQ1170 Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Can not print
Windows 98 you should istall the driver and test print. If nothing working try changing the cable and test print.
Best Regards
rafique
Feb 18, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
Epson LQ-2180 Matrix Printer Logo
1,204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
