Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer sd p-40
Virtical color adjustment during 'Test Pattern' not enough to make White single line. The Horizontal works fine.It there another adjustment in the back?
Posted by P-Nice on
  • Anonymous Feb 17, 2008
    blurred picture cant line up the convergence the blue and red line are slightly off balance.
Sonny Berry
  • Pioneer Master
  • 8,617 Answers
No you can adjust it through the service menu, but I wouldnt suggest that unless you have the service manual as often you could mess the set up worsee without the service info. Let me know if you would like a link to get the service info.
Posted on Feb 24, 2008
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
    f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
    1. Make sure that the power is turned on.
    2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
    (2) Press the Black or Color button.
    The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
    3. Check the print head condition.
    When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
    See " Printing the Nozzle Check Pattern".
    If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
    If the problem is still not resolved, replace the FINE Cartridge with a new one.
    See " Replacing FINE Cartridges".
    If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
    Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
    NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
    You need to prepare: a sheet of A4 or Letter-sized plain paper
    2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
    3. Open the Paper Output Tray gently, and open the Output Tray Extension.
    4. Print the nozzle check pattern.
    (1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
    The nozzle check pattern will be printed.
    5. Examine the nozzle check pattern.
    See Examining the Nozzle Check Pattern.
    Examine the nozzle check pattern, and clean the Print Head if necessary.
    1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
    See " Cleaning the Print Head".
    (A) Good
    (B) Bad (lines are missing)
    (2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
    (A) Good
    (B) Bad (horizontal white streaks are present)
    Post back!
    Oct 26, 2010 | Canon Office Equipment & Supplies
    How do you set convergence
    What is your Make and Model number?
    I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
    see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
    Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
    Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
    SC 329 code Aficio 550
    · SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
    · SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
    · SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
    · SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
    · SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
    · SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
    Use the value printed after “P” on the new LD unit as shown below.
    NOTE: Do not use values printed after a “V”.
    3. Press the “Enter” key.
    5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
    2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
    “192”, “240”).
    dpi).
    2. Press exit, then touch the “Copy Mode” key on the operation panel to access
    4. Press the “Start” key to print the test pattern.
    5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
    Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
    No. Test Pattern
    0 None
    1 Grayscale 1
    2 Grayscale 2
    3 Grayscale 3
    4 Grayscale 4
    5 Grayscale 5
    9 Hatch Pattern
    10 Cross Pattern
    11 Slant Pattern
    Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
    No. Test Pattern
    0 None
    8 Full Dot Pattern
    9 Black Band
    10 Trimming Area
    11 Argyle Pattern
    16 Not used
    21 Blank Page
    Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
    Color problem
    Did you try alignment of color convergence in setting up. Try this
    1 Press MENU
    2 Select SET UP
    3 Select CONVERGENCE
    4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
    5 Use arrow keys to aline the red cross to the white cross.Press set/enter
    6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
    I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
    Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
    Pioneer SD-P50A5-K 50" Rear Projection Television Logo
    37 people viewed this question
    Top Pioneer Televison & Video Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
    Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
