Question about Panasonic KX-T7730 Corded Phone
HI! Um using a KX-T7730 switch board and have two more extensions now i want them open an be able to call out not through the switch board,so how do i do that?
Posted by mizryt on
martin hogg
    Scholar:
  • 157 Answers
The user manual will help you, here is the link http://www.westlakecom.com/KXT7700-User-Guide.pdf
Posted on Jan 09, 2008
How to set welcome greeting to panasonic KX-T7730
The 7730 is a smartphone (PT) that connects to a Panasonic Hybrid exchange such as the KTES824 as an EXTENSION not a CO.
When you say greeting do you mean a recorded greeting when calling the extension?
In the 824 switch you will need to activate the Automatic Attendant (AA) that is built-in
Oct 28, 2013 | Panasonic KX-T7730 Corded Phone
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
Changing names for extensions on KX-T7667
How do I change the name on one extension please.
Sep 24, 2009 | Panasonic KX-T7730 Corded Phone
How do you program a Panasonic KX-T7730?
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
May 18, 2009 | Panasonic KX-T7730 Corded Phone
Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
May 13, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Need to program pf buttons on kx-t7730
Press Program Button
Press Button to be Programmed
Dial 1 - Plus extention number to be stored on button
Press button directly under 'ENTER'
Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
Changing company message on KX-T7730
hi there! can you please help me? how can I create/record a voice message? Thank you.
Nov 26, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
140 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
