Question about GE RM24912 Universal Remote Control
NEED CODE Hi I need a code for my 29"fisher t.v.
Posted by ldowns on
Anonymous
HI I need codes for G.E. remote model rm24912-3 for a Hitichi T.V. to be programed
Posted on Jan 01, 2008
William Rayburn
  • 934 Answers
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Help with and f4 fault code on a fisher and paykel disher
Without the model number I have to guess.
Fault code 'f4' means "faulty temperature sensor or element".
Here is a link to User manuals:
http://fisherpaykelparts.net/index.php?blockitemid=29
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Fisher Dishwashers
Hi, digivox v13-02 need code.Can anyone help UK 09-02=09
e7 d3 69 2e 6f 38 ea 78
a1 38 06 29 24 29 8d 2b
try these gud look
Feb 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes
HI TRY THIS ONE BRO OR SISTER
NEW FROM TODAY IT WORKED AT SOUTH EAST / WEST LONDON
5A01 CODE
00=E7 D3 69 2E 6F 38 EA 78
01= A138 06 29 24 29 8D 2B
ENJOY MY FRIENDS
Jan 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Telewest codes
Hi 5a01 code working fine in South East/West.
And work at 30/Jan/2009 At 11:00am.
00= E7 D3 69 2E 6F 38 EA 78
01= A1 38 06 29 24 29 8D 2B
Enjoye my friends.
Jan 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
NTL CODES FOR STARVIEW3 in Hampshire
HI FRIENDS TRY THIS ONE ITS WORKED TODAY AT SOUTH WEST /EAST LONDON
5A01 CODE
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Hi. My Eurovox has stoped working and is constantly searching for an update. I am in Manchester and am desperate to watch the match today. If any one could help it would be greatly appreciated.
These are the latest codes
you will probably need the telewest codes in the m'cr area ,but they are changing on a dail basis at the moment
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 29/11/2008
PROVIDER CODE: 5C 01
KEY 00 = 00 58 8D CF 27 98 04 ED
KEY 01 = 2A E0 72 B0 9E 07 9B 5D
TELEWEST KEYS -- KEYROLL 29/11/2008
PROVIDER CODE: 5A 01
KEY 00 = 98 B0 BA 52 D3 21 08 B4
KEY 01 = D2 EA 29 B7 B5 52 E9 AD
PURE NTL KEYS (UK) -- KEYROLL 29/11/2008
PROVIDER CODE: 54 01
KEY 00 = CD 11 58 05 EE 96 E7 F3
KEY 01 = EA B7 BF B2 D5 AA 46 AB
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
Nov 30, 2008 | Televison & Video
Codes for eurovox max telewest/virgin bradord area
5a 01 North west
00- aa b7 d1 d9 ce 8e 83 af
01- a1 38 06 29 24 29 8d 2b
Sep 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Televison & Video Logo
135 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
