Hello! I have a 2004 Ram 2500 with a fresh top half rebuild; new pistons, rods, valves, springs, throttle body, map sensor and she will start but will only idle at 400rpm roughly then stalls out without hesitation! Water has been seen coming from tailpipe as well! Please help!
New throttle should be set screw bring up to 700rpm.
There isn't one. Computer controlled.
Look closer should be one.
It is computer controlled!
With out see it running on a scanner. Maybe the IAC or throttle body. Does it have any codes. Did you erase codes after rebuild? Any time I do a rebuild on engines and transmission, the codes have to to erased. Other wise you are trying to run a new part on old PCM codes. Codes have to be erased.
Already replace throttle body! Have not taken to echanic for computer reset however, we did take out the pcm and disconnected the battery! It does not throw any codes either!
Did you replace the computer? Is it a drive by wire/electronic throttle. Can you drive it with the throttle open, Giving it gas? Electronic throttles have a learn process, with a rebuild it also has a crank learn process. If you replaced the computer it has security( does the light stay on or blink fast). It starts up so ignition isn't the problem. But it could be fuel, check fuel pressure. One other thing is, are all the grounds connected.
Did not replace computer! Would that throw a code? Can't drive it at all, it stalls out when foot not on gas pedal! No lights are on throwing codes at all! All grounds have been checked and rechecked! How do we get the learn process complete if she won't drive down the road?
When you start it, does it only run about 2 seconds? if so look to security. Dodges can be reset by locking all doors and the hood. Use the key FOB to open or open the drivers side door with the key. When it does run, does run smooth or rough/stumble? Might want to check fuel pressure. When I do rebuilds, I double and triple check certain areas. Especially timing.
New timing chain going on today! Looking for a pressure gauge too! Runs rough at idle, when she will idle! Foot on the pedal seems to run smoother!
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
Car Stalls and idles low
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
are many other possibilities causing these idle issues.Engine idles rough.
There
I
Click
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at
idle after engine rebuild?
1999 Ford F-150 Idles rough and quits when gas
pedal is pressed less?
Engine stumbles coming off idle when warm?
Erratic idle on car?
3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
GMC Sonoma Stalls and idles low
GMC Idle Air Control (IAC)
Valve Replacing?
1996 Camry intermittent
engine failure while idle?
Engine quits at idle?
Car overheats and Air blows
hot at idle?
High
Idle Problem
While stop engine idles
like cylinder missing?
Idle flair is noticed on car? Rough idle? car
will not idle? Erratic idle speed?
High rpm in neutral? Inconsistant high RPM in
neutral?
Vehicle stumbling at idle
and shows code 54?
Rough idle, staling and Erratic shifting?
These
details will help.
Thanks.
Engine stalling and rough run
issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
