Question about Kodak EasyShare M853 Digital Camera
Charging battery i have a new m853 and i dont know how to tell if my battery is charging or not. i have everything pluged in and there is a green light flashing and im not sure if that means its charging or its not.
Posted by unna on
  • 1 more comment
  • Anonymous Jan 01, 2008
    ready light keeps flashing, like it wont focus and the flash stopped working after only a day also the little shutter things over the lense wont close anymore, the camera charged fine but i only got to use it for about 50 shots and everything went wrong...does anybody know what all the little screen icons mean, i keep having a red AF showing up on the left side!! HELP!!
  • Anonymous Mar 10, 2008
    i have m853and i dont know how to tell if my battery is charging or not. i charge my m853 using usb computer, theres no light flashing..what is this mean..
  • bspiva Mar 23, 2008
    I have the same problem. Pretty much I got one charge out of the original battery (purchased 4 months ago) and it has been useless since then. This is so disappointing since Consumer Reports rated it a Best Buy (that's why I bought it). I will be calling Kodak on Monday to get it repaired.
Anonymous
Same problem tha battery does not charging using USB charging
Posted on Feb 19, 2009
Anonymous
I have m853and i dont know how to tell if my battery is charging or not. i charge my m853 using usb computer, theres no light flashing..what is this mean..
Posted on Mar 15, 2008
Anonymous
Take it back to the store get your money back and then go out and get a real camera. The m853 is a piece of junk. I had the same / similar problems and Kodak is clueless about the problem.
Posted on Mar 02, 2008
Will not charge...
probably the bat is dead
Apr 09, 2010 | Jazz DV-179 Digital Camera
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from camera. If not could you tell me the serial number of each cable. Also would a universal USB cable be...
Yes, you can use the USB cable to charge the battery. But you need to insert the cable into the computer USB port, no the USB HUB, and the computer is on, not in sleep mode.
Jul 01, 2009 | Kodak EasyShare M853 Digital Camera
My Jazzy wheelchair will not charge or run
First have the batteries tested to be sure that they are good. Just because they are "new" doesn't mean they are good. Then with the batteries disconnected plug the charger in and turn the chair on. This will tell you if the charger is good.
If both of these are good then you have an electrical problem. You need to call a local tech.
Nov 13, 2008 | Select Jazzy Used Electric Wheelchair
Lens error and camera battery not charging.
SORRY TO SAY, BUT I AM READING HORROR STORIES ABOUT THIS MODEL OF CAMERA AND IT'S CHARGING OR LACK OF CHARGING SYSTEM. IT SEEMS IT IS A MAJOR PROBLEM WITH THE M853 AND ABOUT THE ONLY SOLUTION PEOPLE ARE FINDING IS USING A SEPARATE CHARGING BAY. IT SEEMS THAT VISTA HAS A POWER MANAGEMENT SYSTEM ON USB PORTS THAT TURNS OFF THE POWER ON UN-USED USB PORTS AND THAT IS WHY THEY ARE NOT CHARGING. YOU NEED TO GO INTO THE USB PORT SETTINGS AND RIGHT CLICK THEM AND DISABLE THE SETTING THAT ALLOWS THEM TO SHUT DOWN POWER TO THE USB PORTS. IT ALSO SEEMS THAT THERE IS A LOT OF TROUBLE WITH THE MAIN BATTERIES IN THE M853 FROM THE VERY FIRST TIME YOU TRY TO CHARGE THEM. THEY SEEM TO NOT WANT TO TAKE A CHARGE. I KNOW ALL THIS IS BAD NEWS BUT GO TO GOOGLE AND PUT KODAK EASYSHARE M853, NOT CHARGING AND READING THE STORIES FOR YOURSELVES. THEY ARE NOT PRETTY. BEST ADVICE I CAN OFFER IT SEEMS IS SEPARATE CHARGING STATION AND DEDICATED USB PORT YOU KNOW IS HOT. GOOD LUCK ON THIS ONE. IF THE CAMERA IS FAIRLY NEW, I WOULD CONSIDER RETURNING IT! THIS ONE HAS A REALLY BAD TRACK RECORD. IF I CAN HELP MORE, REPLY TO: ARCLIGHT1217
Nov 05, 2008 | Kodak EasyShare M853 Digital Camera
M853 camera
it is under warranty .....go to kodak service ....please
Oct 26, 2008 | Kodak EasyShare M853 Digital Camera
Kodak MP 853
Use the USB cable and connect that to the PC and try to turn on the Camera now.. Does the green amber light flash? If it didn't you have a problem with the Camera.
Jul 22, 2008 | Kodak EasyShare M853 Digital Camera
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Charging battery
I have the same camera.
But when your camera is flashing the green light, that means it's transferring pics.
If the light is just green on the camera, that means that it's charging i think.
But i don't know how to tell when my camera is through charging is my problem.
Nov 23, 2007 | Cameras
Kodak EasyShare M853 Digital Camera Logo
560 people viewed this question
Top Kodak Cameras Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Kodak Camera Expert? Answer questions, earn points and help others
