2007 toyota camry LE 4 cylinder hot air don't blow out of vent when turn heater on after the engine warm up, the thermostat been replace still no hot air just a little warm air the heater fan is blowing good on high how to fix this problem and what to check?.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
where is the door airflow control box located can you send me pictures on how to replace it?
Check behind glove box for the Blend Door Actuator this opens and closes your vents
