Question about Bell Sports Scout Jogger
How do I fold the Bell Jogging Stroller?
Uggg... can't figure it out.
Posted by Belljogger on
  • Anonymous Feb 16, 2008
    I can't figure it out either. They should post the manual online!
  • Anonymous Mar 16, 2014
    how do you fold the two-way jogger stroller down?
Anonymous
OH SNAP!! I just went back and figured it out. So provided your Bell Jogger Stroller is like mine, here's what you do: look for the black plastic clips on the sides of the frame. As you face the stroller head-on, these clips should be on either side of the passenger area. The clips have semi-circular grips. Pull up on these to release the clips. This should allow the push handle to fold down toward the floor. Then make sure the snaps holding the cargo pocket below are UNsnapped, allowing the stroller to completely fold in half. To set it back up again, reverse the process although I would re-snap the snaps last of all.
Posted on Feb 16, 2008
agmcnaughton
(800) 456-2355 is the customer service number for Bell could give them a call
Posted on Dec 19, 2007
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Can't turn on my GPX ML451B MP3
i need help i cant turn my mp3 on uggg
Feb 01, 2012 | GPX Audio Players & Recorders
My unit was cooling yesterday and stopped today i put my gage it was 0psig i found a leak on the condenser fix leak and notice the condenser was so hot and not running not even humming.What next iam an...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season.
Jun 16, 2011 | Heating & Cooling
My ipod is not opening.
for ipods you have to have itunes on your computer
Jun 30, 2009 | Apple iPod touch
Jandy Lite 2 LG250N- Heat Exchanger cracked over winter
Yes I just had the same problem, the guy that I bought the house from told me to drain the pump and the filter,etc. But failed to mention there is three brass plugs on the side of the unit, so the heat exchanger cracked, but i took it to a general welding shop and they welded the crack up so that saved me a bunch of money That is all you have to do
May 16, 2009 | Jandy Laars Lite2 Lg 250,000 Btu Heater
WON'T SPIN
This is joyce
Hi sorry! I dont know what you did, take top back off see if you left a wire off because I think you did I dont think its anything serious, I just think its a wire to transmission. hope this works. if not give me your model # and make and let me see if I can do some research on it.
joyce
Feb 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool lut..II
The manual will never have this information.You have a machine that wont spin but will drain ,correct?The motor coupler is the most common repair if thats the case.Usually you can tell by pulling out the washer and looking at the floor under neath for fine black/white plastic shavings,almost like a powder that would be sitting right there on your floor.If you see this ,let me know.I'll say this for sure,If you are attempting to replace this your self ,I will guide you the best and fastest way through it,cause its not going to be easy.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bell Sports Scout Jogger Logo
1,965 people viewed this question
Top Bell Baby Gear Experts
NOEL
NOEL
 Jojo
Jojo
Marty Warge
Marty Warge
Are you a Bell Baby Gear Expert? Answer questions, earn points and help others
