Question about Bose 3 2 1 GSX System
Bose 321 321 will not turn on.
Posted by dadd53 on
  • 1 more comment
  • bobschutte Feb 23, 2009
    321 System will not turn onchecked connections and all appears well.
    Need Help.
  • Anonymous Apr 23, 2009
    i moved my system box the DVD player part. unhooked the connections and wipped were it was cleaning. Then I hooked up the cords an I get no display on the DVD box. It's like there is no power going to the box
  • Anonymous Apr 30, 2009
    We had a power outage and the 321 system, tv and dvd are all hooked up to an expensive surge protector and nothing in my house was damaged. I have unplugged it and still only get a red light on the remote module - it will not turn back on?
david pickell
  • 30 Answers
I also have a 3-2-1 system with similar issues. this was unplugged to relocate an then would not power on. by opening the sub I found the fuse was blown. I replaced the fuse and restored power to the unit but then had no sound. I replaced the FET labled irfiz44n, and restored audio to the satallites but I only get a buzz from the sub. I'm stumped on this one. I hope this was helpful.
Posted on Jun 05, 2009
Anonymous
Same problem..it was working fine, shut off to untangle cords & it would not turn on
Posted on Dec 09, 2007
3 Related Answers
Anonymous
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
Anonymous
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Oct 17, 2008 | Bose 3·2·1 II System
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
Bose 321
got the same problem
Jul 05, 2008 | Bose (321GS) System
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Connecting headphones to bose 321
try pushing mute and then turn volume up
Aug 22, 2007 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
548 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
