I used my self cleaning option today for the first time on model #7903668*. All was fine until about halfway through it stopped and started beeping. The message on the digital screen is now reading F90. I have to keep the door open now because it still continues to beep even after I press the stop button. I would really appreciate some help here. The instruction manuel says nothing worth while. THANKYOU!!!!!
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Second attempt at self cleaning and 20 minutes in, heard a series of beeps. Out of concern attempted to call repair center for explanation, was told no techs available additionally given Kenmore number to call and no one available until December 26. Have decided to research it on my own on the internet to which point I found this page where a similar issue compels me to submit a similar report. The oven appears to be continuing self clean mode without error, however am concerned there is no explanation for what appears to be warning signals (series of beeps).
