Question about RCA Audio Players & Recorders
I need belts for rca sct-520cassette player - RCA Audio Players & Recorders
Posted by Jim Skweres on
1 Related Answer
Grubhead
Grubhead
  • 5720 Answers
SOURCE: i need drive belts for
All you need to do is measure the diameter of each belt in mm, then enter "Cassette Drive Belt ??mm" into Google.
Belts are universal and not generally unique to any maker. Measurements do not need to be spot on!
Posted on Sep 22, 2010
Replace belts on realistic sct-30
I can't tell you how to change the belt on your model though I have changed many belts...
Some belts are fairly straightforward to access and others are more like a torturous route march but once the belt has been accessed, the next problem is identifying the belt cross section and diameter.
Buying a belt from the manufacturer as a spare part is likely to be expensive and often difficult as the trade generally prefers to obtain replacement belts from a general component supplier meaning the manufacturer needn't keep any stock.
Replacement belts are listed in diameter of length size increments and cross section shape and size. If you know the size of belt needed, ordering is easy but belts begin to stretch from day one so measuring the old belt would be useless and using string or a tape around the pulleys also useless.
Typically a new belt of the right size must be stretched to fit around the pulleys - some considerably and some not as much and mostly by how much smaller the new belt needs to be is pure guesswork, consequently it usually pays to order a selection of sizes and choose the one that provides the best result.
Before fitting it is well to remove all traces of residue and oil or grease from the pulleys and to slightly abrade any highly polished driving surfaces with something like Scotchbrite.
2answers
Rca rs2650 tray wont open and cd wont play
Remove the CD tray the drive motor and gear is joined by a belt. I used a matching rubber band it works. Most of these drive motors. have a belt for safety. Important to replace the CD tray at the same location for line-up with your CD player drive. If you can get couple manufacturer belts do so. The belt is little tougher than the rubber band. And clean all your moving parts gently .
Need Motor Drive Belt for RCA DRC8295N
packs of assorted belts sizes can be purchase at you electronic shop
1helpful
Need a pdf manual for maganavox MRV700vr
Magnavox has the manual for the MRV700vr/17B dvd player on their product support page: http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=BLURAY_AND_DVD_CA&sct=DVD_PLAYERS_SU&session=20120117070917_216.183.195.169&grp=SOUND_AND_VISION_GR&ctn=MRV700VR/17B&mid=Link_UserManuals&hlt=Link_UserManuals . The direct link to the manual is http://download.m4c.magnavox.com/files/m/mrv700vr_17b/mrv700vr_17b_dfu_aen.pdf .
I had no problems accessing the Magnavox site with Firefox and Adobe Reader. I do not have a Mac to check if the link works in Safari.
I hope this helps.
1helpful
I need drive belts for rca sct 550
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
Need belts for
Your best bet is to contact MCM electronics and use their cross-reference service to get a more common belt number. They should have the belts that you need. I would give you the numbers, but I don't have a listing for your specific model.
Keep us posted.
Dan
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
