Question about Bunn Coffee Makers & Espresso Machines
Bad leaking bunn commerical VPR pour-omatic
It's a bunn coffee maker that has 2 warmers top and bottom. It is leaking water all over. How do I fix it
Posted by Bernie Wheater on
Walter McGuire
    New Friend:
  • 4 Answers
I repair BUNN vpr's everyday for a living...they are very much so serviceable, and parts are available from BUNN. When water is poured into the machine, it enters a fill basin that is fastened to the top of the tank. A silicone seal between the basin and the tank lid is most likely where the leak is coming from. It might also be a thermostat grommet.
Posted on Mar 14, 2017
Marvin
    Top Expert:
  • Bunn Master
  • 85,239 Answers
You will need to replace it, parts are not made for repair except under warranty.
Posted on Nov 30, 2016
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
Sep 15, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
629 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
