Do not bother. Continue using the m/c. If the inlet water quality is good do not worry. This is a sensor sensing fault, even if the salt is fully loaded.
If the wash quality is good without salt continue.
Otherwise add salt at regular intervals. Trying to fix this fault will lead to another and so on. Now machine works for you continue enjoying!
its the same water that rinses both sections just different arms, the one directly under the top basket usually cleans both cutlery and top basket. it could be a posibility that the arm itself is contaminated with waste that is too large to push through the holes and is now breaking up making a mess on teh glasses. (I have seen it before with melon seeds) remove the arm and rinse backward under a tap. make sure that the salts are topped up as well this is very important if the salts run out you will not regenerate the resin beads which are used for water purification on the last rinse so this could also rinse with dirty water.
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet.
Suck out as much water as you can from the salt
cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature.
Good luck
