Question about Whirlpool Ovens
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
Posted by Theresa Hunt on
Bill Boyd
    Top Expert:
  • Whirlpool Master
  • 53,814 Answers
Whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Posted on Nov 30, 2016
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Oct 29, 2009 | Whirlpool AKZ159IX Oven
Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
May 17, 2009 | Whirlpool AKZ159IX Oven
Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Dec 12, 2008 | Whirlpool AKZ159IX Oven
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Open Questions:
Ovens Logo
48 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
