Question about KitchenAid Ovens
Is there a thermal fuse on my kitchenaid kebs277sbl2? The lower oven is not heating beyond warm. The broiler doesn't work at all. This happened after self cleaning cycle.
Posted by Tim Tight on
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Our oven's heating elements will not come on althought the display seems to work correctly.
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. Catriver..post back.
Posted on Dec 18, 2006
Anonymous
SOURCE: WHIRLPOOL OVEN
nice, it'd help me a lot thank you
Posted on Jan 19, 2008
Anonymous
SOURCE: Dacor ECD230 lower over won't heat up after cleaning
Under the panel between the ovens there is a little square box with a reset button on it.
Posted on Feb 08, 2009
Anonymous
SOURCE: OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
Anonymous
SOURCE: After using the self cleaning
If you slide your oven out and take off the center panel on the back of the oven you will see the thermal fuse. If it's like mine, it will be located (looking from the back of the oven) upper right hand side. It's an oblong loooking part with two terminals with wires attached to it and two screws holding it on. Once you take it off, you will notice that it is flat on the back side and you should be able to see part # 9759242. Only reason I know this is that I have just removed mine and am going to see if I can find one locally. Same thing happened to mine after putting it in the cleaning cycle to clean up after the holidays.
Hope this helps!
Robert
Posted on Dec 27, 2010
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
KERC506HBS3
One thing I've run across is that the heater leads burn off the terminals inside the oven cabinent.
May 09, 2014 | KitchenAid KEBC107 Electric Single Oven
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
Oct 14, 2009 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Ovens Logo
105 people viewed this question
Top KitchenAid Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
