SOURCE: ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
