The steering gear box has an adjustment screw on the top cover. Loosen the lock nut and turn the screw clockwise until the slop is reduced. Jack the front end up so both wheels turn freely. Push the wheel right and left while watching the suspension components. If they move up and down. The control arm and ball joints need replacing. Have it done at a good shop that does alignments.
SOURCE: where is 2003 saturn ion thermostat?
FACEING the ENGINE It is At TOP RIGHT SIDE Close to Master Cylinder takes About 1 hour to Replace Have Fun its a EASY One
Please Dont forget to RATE ME Thank You
Remove the feed pipe
Installation Procedure
Install the thermostat and retaining sleeve with the dimple placed into the housing slotImportant: Lubricate the O-ring with soapy water or coolant before installing the O-ring in the water pump.
SOURCE: when turning the steering wheel of my 2003 Saturn
mine did the same thing. Where the steering column goes through the firewall (floor) there is a rubber seal. That seal has gotten dry. Apply a small amount of lube where the shaft goes through and turn the steering wheel. This helped eliminate my squeal.
SOURCE: my 2006 ION steering makes clunking noise which
I have had that problem with my wifes car,i called a mobile repair guy to come out and tighten something in the steering column,cost me about $50
SOURCE: 2003 Saturn Ion spark plug replacement
go to autozone.com and set up a free account. You will then have access to vehicle repair guides and can get all the info and diagrams you need, plus help with troubleshooting! Hope this helps!
