Question about XO Vision Car Audio & Video
Can anyine help me with a pinout for x348nt xo vision wiring harness
Posted by Joshua Cain on
1helpful
Installing an XO Vision XD103 to a 2001 Ford Ranger
Easist way to install it is to get a dash kit,End a wireing harness adapter kit that plugs into the factory radio harness,
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
2helpful
The connector does not match the wiring harness connector for car
you can buy wiring harness adaptor from any car audio shop or try Ebay.
I have white/brown and white/blue left on wiring harness on dual xdvd 9101 on my factory harness i have the blue and orange wires left
You can download the User Manual (including the wiring diagram), from http://www.dualav.com/mobilevideo/xdvd9101.php. Anyway the blue/white cable will be +12V, after the 9101 is switched on, and can be used to power a electronic antenna, a motorized antenna, a amp, etc. The white/brown cable can be connected to the reverse light and would automatically open the panel and switch to rear camera operation when the reverse gear is selected. The wires left on the factory harness can be anything. MAYBE the orange wire is the car-light and MAYBE the blue one powers up an antenna-amp. It should be possible to find out the function of these wires investigating the pinout of former conected equipment.
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
XO-2703 WIRING
Try these guys - although they only allow installation by licensed installers, so they may not supply parts. http://xovision.com/contact.htm Wiring harnesses for this type of application will differ considerably from vehicle to vehicle depending on the location of the monitor and player and the route through which cabling has to be threaded, so they are usually constucted in situ. The connectors on these units should be standard, so any auto electric shop should be able to wire it up, but be careful not to void any warranty on the monitors. Hope this helps :)
Car Audio & Video Logo
Top XO Vision Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Relax
Relax
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
