Question about Shop Vac Vacuums
How to pull off the washer holding the motor in ridgid shop vac to change brushes
Posted by Dale Maes on
3 Related Answers
Anonymous
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: need to change the motor brushes in Shop Vac model
Would like to know if you still need help with you problem. If so go to the link below.
http://www.ereplacementparts.com/
Posted on Dec 05, 2010
kjhbretge
Roger
SOURCE: My ridgid WD06250 shop vac has bad motor brushes
Hi, replacements can be found at amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Posted on Dec 17, 2014
I am unable to take old filter off my Ridgid portable 4 gallon vac.
You press in the black cap in the middle of the filter while you pull up on the black "handles" around the edge of the filter. It just pops off.
Jan 20, 2011 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you get to the motor for the ridgid wet dry vac model #WD 12450
the manufacture does not replace the brushes...depending hon how old it is you might be able to get the powerhead replaced. The motor is made in China. I heard of some guy cross refrencing the motor brushes at ACE hardware if you can believe it
Sep 14, 2009 | Vacuums
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vacuums Logo
49 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
