Question about Oreck Vacuums
Owner's manual for oreck orb660mc - Oreck Vacuums
Posted by William Bobo on
The Vanguardian
    Master:
  • 531 Answers
It was hidden on Oreck's manual site under the 550. The manual for the 550 covers the 600 and 700 series too.
http://demandware.edgesuite.net/aajc_prd/on/demandware.static/-/Sites-oreck-Library/default/dwc7b4517e/images/userguides/FloorMachine-Orbiter-550-userguide.pdf
Posted on Nov 28, 2016
How do I reset the carpet motor on my Oreck vacuum?
first,do you have an owners manual for this orek? second,if you can't find it call orek and they will gladly tell you.
Aug 30, 2014 | Oreck XL2200 Bagged Upright Vacuum
Oreck owners manual model xl 21-600ECB
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link and download your Oreck Product User Guide:
CLICK HERE
All the best
Ben
http://www.oreck.com/Owners-Guides
Oct 03, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I need a manual for the oreck floor steamer
Hi! Since you didn't mention the model type of your floor steamer, i'm giving you the link where you can see the user's guide for all oreck floor steamers. So, access this link (http://www.oreck.com/Owners-Guides) and go to the floor machines category (under electric brooms).
I hope this will work for you! Have a nice day!
Sep 02, 2011 | Oreck steam-it Stick Vacuum
Hi, I purchased a used Oreck BB870-AD canister vacuum cleaner, but it didn't come with the manual or any bags. Can you tell me where I can find the manual & what type of bags do I need?
The manual is available as a PDF here: http://www.oreck.com/Owners-Guides . Scroll down to the Canisters section and then select the link for the Compact Canister vacuum.
The replacement bag that you should use is: Oreck Replacement Treated Filter Bags (12 pk. with
1 Micro Filter) No. PKBB12DW which cost $14.99 for each package from Oreck. On the Oreck site, these are the Hand-Vac Bags. See: http://www.oreck.com/Hand-Vac-Bags to order them online.
I hope this helps.
Mar 21, 2011 | Oreck Vacuums
Need manual for steemer manf by Oreck Rinse a matic
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/XLS465.pdf
Oct 12, 2009 | Oreck XLS465A Upright Vacuum
Dont know how to put an oreck vacuum bag on!!
Go to this link and tourds the bottom you will find your vacume model # for the manual. It will tell you hoe to change the bag.
http://www.oreck.com/customer-service/owners-guides.cfm#
Good Luck
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck 9100C Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=647356
Oreck 9100C Vac
Posted by thecleaner on Jun 04, 2008
How to I replace both belt and brush correctly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL 9100C Ultra Bagged Upright Vacuum. The best way to install the belt is to put the belt on the brushroll 1st and then install the brushroll, the brushroll has marking on the top and the bottom of the bearings stating NEW or USED / OLD and install them identical on both sides and then use a belt puller to stretch it onto the motor pulley. The best place to get instructions on how to install the belt and brushroll is the owner’s manual and an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Rplacement part
Her is the oreck manuals web page.
They can also tell you where to get parts.
Feb 20, 2008 | Oreck XLS700A Upright Vacuum
Vacuums Logo
107 people viewed this question
Top Oreck Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
