Question about Logitech Audio Players & Recorders
It's 14.3 to 14.6v unregulated, rated at 4.5amp continuous output.
Posted on Jun 11, 2021
The transformer should have the output voltage listed, probably in very small print, on it. It also should show the input voltage. If it does not have the markings you can measure the voltage output with a volt meter.
Posted on Mar 02, 2019
You can't couple AC (from transformer) to DC (from a battery)..you will have lots of fireworks if you try
Posted on Feb 01, 2018
SOURCE: x230 logitech not working.
i did the same to mine,
just replace the power transformer with one that accepts 110-240 volts
easy to do, but check cost might be better to buy a new set depends on your situation
Posted on Jun 11, 2009
SOURCE: Transformer blew on Hk395 speaker sysytem
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
Posted on Aug 16, 2009
SOURCE: LOgitech x230 - problems with sound
check there are no lose connections such as the jack not being inserted correctly or a defective plug
Posted on Nov 01, 2010
SOURCE: Logitech Subwoofer X540 PC speaker System
HELLO THERE AND WELCOME TO FIXYA
IF YOU ARE NEEDING PARTS FOR YOUR SYSTEM YOU CAN GO TO THE FOLLOWING
Wild Burro Audio Labs - DIY Full Range Speakers THEY CAN GET WHAT YOU NEED AND EVEN HELP WITH SPECS AND REPAIRS AND ALSO IF YOU CONTACT THE MANUFACTURE OF THE SYSTEM THIS IS A GREAT HELP FOR YOU OK?
BEST REGARDS MIKE
Posted on Dec 29, 2011
