Dyson V6 Absolute Bagless Cordless Hand Vac Logo
P
Pat Rooney Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
Think Crucial
Level 3:
Master:
  • Dyson Master 894 Answers
  • Posted on Nov 30, 2016
Think Crucial
Dyson Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711166
Points
8395
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Have 1 year old hand held v6 motorhead. When pressing the trigger to start. The unit surges on and off repeatedly on a 1 second pulse. How do this get corrected
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
I have a dyson V6 Mot?rhead model Ju4-us-GBR7075 My machine when I push the power button the machine stops and goes
Ava B.
I have a dyson V6 cordless vacuum. When i pull trigger to start vacuuming, it revs up and stops, revs and stops. Is there a fix for this?
Ava B.
My Dyson V6 started suction and motor pulsated instead of staying on. Filter cleaned - nothing blocking wand....help
Ava B.
I have a Dyson V6 Slim about a year old. It's stopping and starting - not continuous power. I have cleaned the brush the canister and the filter and it's still not working right. Help!!!!
Ava B.
Dyson V6 animal powerhead starts and stops does not run continuously
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
My Dyson v6 animal is pulsating but has been cleaned and been on charge All night
Ava B.
Dyson absolute
Your hose is clogged. Take it off and clear the obstruction. I would also check to be sure something isn't jammed in the inlet to the clear canister. If that is not it, you need to clean your filter
Jan 26, 2014 • Vacuums
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
