Screen gone bad will need to replace it. Cause can be liquid spill on it some thing poke hole or they just go bad after a while. They did have a flaw in some models and you had to replace them.
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
546 A Unstable fusing temperature
The fusing temperature varies 50°C or
more within 1 second twice
continuously.
• Thermistor defective(temp. senzors in the fixing unit)
• Poor connection of the fusing unit
• Power supply unit defective
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
