Ovens Logo
Question about KitchenAid Ovens
Outer glass....not interior glass... for kitchenaid superba oven door is needed.
Posted by Laura s on
1helpful
2answers
Im looking to replace the outer glass on an oven door STV008 Vanette GG7000. Can anyone help?. Many thanks.
Hi, Cathy.
The double-glass is held down by the inner framework, which secures with fairly hefty Philips screws.
These screws and frame can become baked on over years of fat / oil being dried and hardened into a shellac-type 'superglue'.
Lay door horizontal, or as open as it will go, pour olive oil over screws and brush edges of window and frame.
Leave to soak (unheated), at least overnight.
The interior of the door has glass wool heat insulation.
Apply rubber gloves and long sleeves if the spiky glass wool fibers irritate your skin (like mine!!).
Unscrew frame, lift glass out.
Electrical stockists which sell stove parts (may) possibly have a match, otherwise search the web, manufacturer, etc.
Jul 10, 2018 • Ovens
2answers
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
4answers
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
9helpful
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
22helpful
5answers
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Top KitchenAid Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
